Thread: uprated clutch or not 1.8T ???
  1. uprated clutch or not 1.8T ???
    alright peeps,
    me clutch is on the way out on my 2000 1.8T - its currently on a remap with 199 BHP - is it worth me buying a uprated clutch or stick with a replacement standard one ? if so which is the uprated one to go for and where to buy from and what should i be paying !
    cheers
    Brett
  2. Re: uprated clutch or not 1.8T ???
    Oct 2005
    Manchester
    I'd stick with a std one if you're not going for more than the remap.
    A mate's 260bhp passat is still fine with the std clutch. Mine's remapped with a few other changes and is fine too.
    Although an uprated clutch will grip better, you'll lose some of the smoothness of the change plus they tend not to last anything like as long as the OEM ones.
    Get a good quality std one, and change the flywheel too as a work clutch can kill them very easily.
    When you say it's on the way out what exactly is wrong? Sometimes they just need bleeding as the hydraulic clutch tends to get overlooked when changing fluid and bleeding the old crap through.....
    Passat 1.8T OEM+
  3. Re: uprated clutch or not 1.8T ???
    133 Post(s)
    1987 Post(s)
    Stay standard.
  4. Re: uprated clutch or not 1.8T ???
    cheers mates,
    basically the travel has got alot longer in a very short space of time and often it just wont go into gear - going in for a service on Tuesday so will get the spanner to change the fluid
    Brett
  1. Uprated clutch for Passat TDI 130
    By conor2949 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-11-2011, 07:49 AM
  2. Uprated clutch
    By thefreak in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-05-2008, 03:46 PM
  3. Uprated Clutch 18t Quattro
    By bez101 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-05-2008, 06:47 PM
  4. uprated clutch?????
    By richie_mck in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-04-2008, 10:28 AM
  5. Uprated Clutch
    By inertia in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-03-2008, 06:10 PM
