Thread: No Red Flashing Alarm Light on Door
  1. No Red Flashing Alarm Light on Door
    Jabamusic Guest
    Hi Folks
    Have noticed that the little red flashing alarm light on top of door no longer lights up after activating the alarm ie locking door.
    I have spent about 30 minutes going thru this forums previous postings but cannot find exactly the same issue (although plenty of alarm problems!!)
    The closest I can find relates to a boot/bonnet sensor fault. Any suggestions how I can either confirm or eliminate this as the cause OR any other ideas?
    Many thanks to one and all,
    Jaba
  2. Re: No Red Flashing Alarm Light on Door
    Jul 2008
    stoke on trent
    does alarm work? lock doors and leave window open to check
    or have you replaced c/l pump recently, alarm may not be activated
  3. Re: No Red Flashing Alarm Light on Door
    Jabamusic Guest
    Hi Many thanks for the reply.
    Sorted. The boot lid was not properly closed so in fact the system was telling me that which I should have checked.
    - Clever things these cars. just wish they ran on water !!
    Jaba
  4. Re: No Red Flashing Alarm Light on Door
    Nottingham
    Hi there,
    I've got the same problem, althought this occured after I changed the window regulator on the door. I thought all cables were connected though when i put everything back in there. Is this possibly related to a fuse?
  5. Re: No Red Flashing Alarm Light on Door
    Barnsley
    I'd say you forgot to plug it in, small 2 pin plug covered in foam easy to miss, easy to check.
  1. intermittent door light/headlight warning alarm
    By warrydave in forum Golf MK3 - 1993 - 1999
    Last Post: 16-03-2008, 12:31 PM
  2. alarm problems flashing indicators
    By malakoffone in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-03-2008, 10:11 PM
  3. interior light flashing when alarm set
    By Lee selwyn in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-01-2008, 07:55 PM
  4. No alarm Sound but blinkers flashing
    By scottjenkins in forum Passat - Archive Topics
    Last Post: 09-10-2007, 09:13 PM
  5. POLO Alarm No Siren Jus Flashing Lights
    By dbrooksy in forum Polo - Derby - Lupo - Fox
    Last Post: 07-05-2007, 03:53 PM
