Thread: Polo engine cutting out - help needed
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 55
  1. Re: Polo engine cutting out - help needed
    #21
    134 Post(s)
    2022 Post(s)
    00609 Ignition output 1 Open circuit/short to earth
    1)Wiring open circuit in earth wire
    2)Wiring has short to earth
    If this code keeps coming back with a new coil, you have a wiring fault which could be in the wire between the body and the engine or a poor connection where the coil picks up its earth.
  2. Re: Polo engine cutting out - help needed
    #22
    Feb 2009
    hi - thanks - i will get this checked but wil this be the cause of the car slowing down ?
  3. Re: Polo engine cutting out - help needed
    #23
    134 Post(s)
    2022 Post(s)
    If the coil receives a poor earth, the spark will be poor so therefore will the engines power output.
  4. Re: Polo engine cutting out - help needed
    #24
    Feb 2009
    hi - my mechanic ckecked all the leads and couldnt find any prob with earth but he connected a new cable from battery to engine coil and all code cleared and never came back so i thought the prob had gone.........BUT as i was driving earlier it started jerking again as if it was about to lose power again..... so looks like something else is causing this....
    any ideas?
  5. Re: Polo engine cutting out - help needed
    #25
    134 Post(s)
    2022 Post(s)
    Fault code read and start from there.
  6. Re: Polo engine cutting out - help needed
    #26
    Feb 2009
    sorry i dont understand last message
  7. Re: Polo engine cutting out - help needed
    #27
    134 Post(s)
    2022 Post(s)
    The first step would be to have a fault code read done and see what is stored. If it is the same code as before then that needs pursuing deeper and if there is another code, have that looked into. If there are no codes it is a fault outside of the ECU’s abilities to detect it and that helps as there are only certain things that can be.
  8. Re: Polo engine cutting out - help needed
    #28
    Feb 2009
    well once the new earth lead was attached the code was gone and never came back. so i am gonna drive it over the weekend as it did judder earlier and then see if any codes are back....
    if not what do u think it would be?
  9. Re: Polo engine cutting out - help needed
    #29
    134 Post(s)
    2022 Post(s)
    I will reserve judgement until I know the results of a code read.
  10. Re: Polo engine cutting out - help needed
    #30
    Feb 2009
    hi - crazy day - loss of power occured 4 times today .. once at 50 mph.... nearly resulting in an accident but anyway......... had the car checked again and this is the code :
    00519 Manifold Absolute Pressure Sensor G71 - not a plausible signal. error occurs intermitently.
    hope that makes sense to you.
    thanks
  1. Polo Engine Cutting Out
    By stevebeall in forum Chat - Completely Off Topic
    Last Post: 04-05-2011, 07:46 AM
  2. help needed please, 8valve golf GTI missing and cutting out
    By chris_b in forum Golf MK3 - 1993 - 1999
    Last Post: 28-06-2008, 07:26 PM
  3. Question polo 1.4 engine code bby needed
    By bobby1 in forum Polo - Derby - Lupo - Fox
    Last Post: 04-06-2008, 02:50 PM
  4. 2000 Polo GTi cutting out
    By bryn_p in forum Polo - Derby - Lupo - Fox
    Last Post: 16-01-2008, 10:23 PM
  5. cutting out polo
    By newboy in forum Polo - Derby - Lupo - Fox
    Last Post: 28-05-2007, 09:20 PM
