Thread: A3 modding to S3 spec??
Results 11 to 20 of 28
  1. Re: A3 modding to S3 spec??
    Aug 2007
    west midlands, uk
    well, the outside would need 2x new front wings & fittings & 2x whole rear quarter panels... which is gonna be pricey for a start mate!
    *if* you can actually get the wings for the s3 they're about £140 per side...
    they're *quite* hard to get unless you're in the trade too, unless you know someone in the trade who could get them in for you...
    the interiors you can pick up on the bayoftheE for £500 upwards...
    my advice would be to go & have a look at it too before purchasing, you know what folks on that site are like *RARE* *MINT CONDITION* etc,etc
    dunno about the clocks/heating anc's tbh...
    good luck!
  2. Re: A3 modding to S3 spec??
    Berkshire
    Clocks are matched to ECU’s & keys… If you wanna change the clocks you’ll need to take the ECU & keys from the vehicle as well. This in it’s self will cause all sorts of issues as I’m pretty sure you wont be able to use an S3 ECU with a tdi…
    Also if you want proper climate control (i.e. air con) then your looking at a massive & unnecessary job and would probably be cheaper to drive to the south pole and bring back a life time supply of ice…
    My mate did an S3 exterior transplant and it cost soooooooooooooo much to do. Your looking at a few grand for the parts then you gotta find some one with the balls to weld the rear arches in…
    GOOD LUCK! ! !
  3. Re: A3 modding to S3 spec??
    Sep 2008
    Birmingham
    Basically the only things that are the same on the two cars are the doors, bonnet, boot and glass. Pretty much everything else is bespoke for the S3. The interior will fit which is a nice upgrade but they are two different cars altogether really.
  4. Re: A3 modding to S3 spec??
    Aug 2008
    north hampshire
    the top spec audi a3 is the 2.0 tfsi or the 3.2 v6 the 2.0 has 200 bhp and the 3.2 has around 240 bhp. the s3 is a 2.0 turbo and has 265 bhp lowered slightly, s3 bodywork spoiler n different alloys. very easily tuned as well, a simple bluefin chip on it can make it put out over 300 and its also 4 wheel drive.
  5. Re: A3 modding to S3 spec??
    Jul 2008
    ok cool so basically i think i'll jsut be looking to fit the interior front wings and bumper and look into the rear at a later date...
    how are the std brakes on the tdi?? good? As long as there up to the task i'll keep them also what sort of things get tired suspension, arms??
    cheers again for the helpful replies
  6. Re: A3 modding to S3 spec??
    Aug 2008
    Aircon can be fitted, lots of work though. You need to have all the wiring diagrams too over and above the complete airbox (it contains evapourator, electric motors and heater fan), control panel, facial etc. You will also need to cut a hole in a plate attached to the bulkhead to take the aircon pipes into the engine bay. Unless you can get a donor with all the parts It will be even bigger nightmare.
    The S3 clocks can be fitted and coded by Audi if you can get the right ones for your model. The easy way to tell the difference is does yours have a digital or analogue clock? Most S3's were facelift and had a digital clock - the wiring and immob is different to the pre-facelift that has an analogue clock and while the wires can be relocated to match, im fairly sure the immob cant be coded to work.
    I would look out for the parts CD - ETKA and repair manual - ElsaWin, both can be purchased of ebay. Without either you will struggle.
  7. Re: A3 modding to S3 spec??
    #17
    Berkshire
    Quote Originally Posted by gixxerk4600 View Post
    Mate, your talking about post 2003 models. The one in question here is a 1999 model.
  8. Re: A3 modding to S3 spec??
    #18
    Aug 2008
    north hampshire
    oh yea, i forgot it was a 99 modal, forget what i last said then!!! my bad
  9. Re: A3 modding to S3 spec??
    #19
    Jul 2008
    yes 1999 spec plz lads anymore advice still welcome, a pic of my cossie for you all for now will get one up of the audi when i get it tomorrow
  10. Re: A3 modding to S3 spec??
    #20
    Jul 2008
    Quote Originally Posted by A3_FSI_2.0 View Post
    also i have digital clock mate so what wold be the best way for me to convert mate?
  1. Which oil for your vag 50* ** spec
    By adzul in forum Golf MK4 - 1999 - 2004
    Last Post: 03-08-2008, 11:26 AM
  2. 506.1 spec oil
    By davidmoore in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-04-2008, 12:30 AM
  3. HELP! A4 Spec
    By wheelybin in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-04-2008, 04:34 PM
  4. v5 modding
    By signmanbeetle in forum Beetle 2000-
    Last Post: 04-11-2007, 09:09 PM
  5. Modding my 2.7T A6
    By giblets in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-02-2007, 04:41 PM
