Thread: golf central locking fault
Results 1 to 10 of 11
  1. golf central locking fault
    Hi, I own a golf gti 1.8 turbo 1999 Mk4. I disconnect my battery to recharge it. After that my key fob will not operate the central locking nor can I open or close any of my electric windows. The service manual shows a fuse relay called FR37 which feeds power to the circuit. The fuse FR37 is not located in the fuse box. Can anyone with a circuit diagram let me know where it can be located?
    Also I have been told you have to reset the central locking and windows after a low battery . Can anyone explain the sequence.
  2. Re: golf central locking fault
    Nov 2006
    Id be interested in this too! I went to lock my golf last night, and the alarm went heywire. Now I can only lock with the key itself, kefobs dont work, neither to the windows or central locking buttons. I thought it might be something to do with the fuses, arent there some inside the engine bay itself?
    Thanks to anyone who can help!
  3. Re: golf central locking fault
    Any body know anything about this? My wife's 2002 Golf GT Tdi is doing the same thing. No key-fob central locking, no interior front lights, no door lights and no electric windows. Any ideas???
  4. Re: golf central locking fault
    Quote Originally Posted by stuman56 View Post
    All sorted now
  5. Re: golf central locking fault
    SHEFFIELD
    As i have just told stuman there is a small 10amp blade fuse that powers all these on drivers side end fuse box on the dash
    I dont work here for the pay,or the enjoyment,so why do i work here
  6. Re: golf central locking fault
    Quote Originally Posted by tonyleach View Post
    Thanks again Tony, both posts were from me
  7. Re: golf central locking fault
    Quote Originally Posted by newso1 View Post
    Checked fuse box again and found 10amp fuse had blown. Missed it first time round. Windows, central locking, alarm and internal light all working ok plus key fob.
  8. Re: golf central locking fault
    SHEFFIELD
    Ah Ha,another cheat with 2names !!!
  9. Re: golf central locking fault
    Nov 2006
    All my fuses were ok, turns out it was a loose wire behind the fuses. Seems its very easy to push the wires behind the fuses out of place when changing them. This one had come loose, even though I hadnt touched the fuses in ages. Also seems that if any one of the fuses/functions connected with the comfort module (interior lights, windows, keyfob locking etc) blows, it all goes t*ts up at once. Does make sense, but a real pain!
  10. Re: golf central locking fault
    hello, can anybody help me i had the drivers door changed as it was damaged, the body shop man had to strip my existing door and refitted everything, when i got it back i want happy as the drivers door lock didn't work with the fob so i stripped it and fixed that, then when i put it back together the windows, mirrors, and key fob only locked the boot so i diconected the battery and reconnected and now when ever i do this they only work for half an hour any advise would be appriciated
    thank guys
  1. Central Locking Fault on 1.8 20v
    By Rubens in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-09-2008, 11:52 PM
  2. central locking fault
    By thomasew in forum Golf MK4 - 1999 - 2004
    Last Post: 27-08-2008, 08:25 PM
  3. Please Help Golf Central Locking fault
    By howard2103 in forum Golf MK4 - 1999 - 2004
    Last Post: 17-07-2008, 08:14 AM
  4. Vag com fault central locking
    By Dozz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-06-2007, 12:12 PM
  5. T Reg Passat - Electrical Fault, Remote Central Locking Fault
    By adriana in forum Passat - Archive Topics
    Last Post: 01-03-2007, 06:27 PM
