Thread: Allroad 2.7T Multitronic - Reverse Gear prob - Help!
  1. Allroad 2.7T Multitronic - Reverse Gear prob - Help!
    Hi All
    I have a 2002 reg 2.7T allroad multitronic which today has added to its list of irritants (see - the wheel vibration posts for an idea!) by deciding to go backwards reaaaaaally slowly - i.e you select R and then have to apply a fair amount of throttle for it to go backwards. Forwards, currently, is fine but its like it has a slipping clutch. Just had the ATF changed at 86K by a specialist and whilst it is under a (dubious) warranty I wanted to check before I ring the crap warranty company if anyone has an idea so I can avoid yet another 'thats not covered' discussion!
    Sean
  2. Re: Allroad 2.7T Multitronic - Reverse Gear prob - Help!
    Mar 2008
    Quote Originally Posted by ALLROADSEAN View Post
    Hi All
    Sean
    Might worth checking if your specialist put enough oil and whether they Gearbox ECU was tuned (VAG COM) whilst puting in the ATF fluid. I maybe wrong but I think once the new ATF is in, some further works needs to be done so that ECU (GBOX) "learns" itself again.
    Maybe a few of the forumites can confirm this?
  3. Re: Allroad 2.7T Multitronic - Reverse Gear prob - Help!
    Cheers mate - its booked back in to the technician tomorrow and it seems that is what he thought so hopefully on the right track! will keep this thread updated so all can see if thats the solution.
  4. Re: Allroad 2.7T Multitronic - Reverse Gear prob - Help!
    Jul 2008
    Surrey
    I had this problem on a car recently, turned out to be a cracked casing for one of the clutch packs inside the gearbox. Ended up replacing the gearbos due to the damage it caused.
  5. Re: Allroad 2.7T Multitronic - Reverse Gear prob - Help!
    Quote Originally Posted by quads View Post
    Hi - engine oil was fine and no faults showed up on the VAG computer system so it is back in now for a warranty investigation - will wait and see... thanks anyway
  1. 2000 Allroad Auto prob
    By slickoneuk in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 31-08-2008, 07:26 AM
  2. Multitronic - reverse gear problem?
    By JPC in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-04-2008, 10:46 AM
  3. Reverse gear problem
    By kenharkin in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-11-2007, 05:51 PM
  4. reverse gear trouble. v reg a3 1.6
    By aswinsco in forum Audi A3 - Archive Topics
    Last Post: 17-10-2007, 08:55 PM
  5. Sticking reverse gear!
    By omar_K in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-08-2007, 12:32 PM
