Thread: What is the correct engine idling speed
  1. What is the correct engine idling speed
    kenny1001 Guest
    I have a 2004 130 TDI Passat, it idles at about 500 revs, i was wondering if this is correct or what is the correct idling speed?
  2. Re: What is the correct engine idling speed
    london/ UK
    Is that an auto ? Iddling speed can be adjusted only with diagnostic equipment...500 rpm is way too low, it should be 800-900 rpm.
  3. Re: What is the correct engine idling speed
    kenny1001 Guest
    it's a manual
  4. Re: What is the correct engine idling speed
    kenny1001 Guest
    Thank you very much for your help, turned out it was just me that could not count, i thought each line indicated 100 rpm but it turns out it is 200 rpm, which means that my car is idling at 800 rpm which is within the normal range.
    Whoops, my mistake
  1. Question speedometer not showing correct speed
    By kozerzoto in forum Audi A3 - Archive Topics
    Last Post: 17-07-2008, 04:34 PM
  2. ticking noise when engine idling
    By roguetone in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-06-2008, 10:47 AM
  3. Fan is always on and engine idling too high
    By motah33 in forum 80 - 90
    Last Post: 13-04-2008, 01:41 AM
  4. Engine Idling
    By A3ANG in forum Audi A3 - Archive Topics
    Last Post: 29-03-2008, 06:27 PM
  5. how do you change where it says engine idling?
    By Jimbo1.8t in forum Chat - Completely Off Topic
    Last Post: 08-07-2007, 04:34 PM
