Thread: Unable to get any gears
Results 1 to 10 of 10
  1. Unhappy Unable to get any gears
    Driving home from Scarborough up Staxton Hill this morning in by 2005 T5 transporter the gears disengauged whilst driving & unable to obtain any gears. There were no strange noises on it doing this & the gear stick & selecter are moving normally, although there is a lot of play on the selector to the gearbox.
    Can any body assist, got to ring vw tomorrow but it is 3 years & 4 mths old so I guess the warrenties out.
    Any help would be much appreciated
  2. Re: Unable to get any gears
    london/ UK
    Pressure plate broken theeths. You will need a new clutch kit. Have a look underneath for broken linkage if no sign of it, then is the clutc pressure plate. Are the brakes ok ?
  3. Re: Unable to get any gears
    Cornwall
    More likely the drivshaft stripped it's splines. I can't remember which one it is that goes. It's quite well known on the T5. Ask the dealer if they will do a goodwill claim.
    The bit that strips is not at either end, it's like a two piece shaft and the bit that goes is three quarters of the way along.
  4. Re: Unable to get any gears
    Westyman Guest
    My daughter's T5 174bhp/6-speed did same thing on Saturday evening. Moved off, bang, no drive. Gear selector engages in gate fine just no drive.
    Of course no idea where the towing eye was.......so looped rope round front suspension for a slow 400 yard tow home.
    It's gone to her local garage now, will report back.
  5. Re: Unable to get any gears
    Oct 2007
    Hi I have seen this happen a couple of times and it was the right gearbox stub shaft which had stripped its splines
  6. Re: Unable to get any gears
    Westyman Guest
    So is that new drive shaft or what? Sorry but no knowledge of Vdub bits as I am actiually a Volvo man but looking for solutions to my daughter's problems.
    I do actually have a little bit of Vdub bits in that the rear brake calipers on my Westfield are from a Golf!!!
  7. Re: Unable to get any gears
    Oct 2007
    If it is as i suspect you will need a new stub shaft,and a new drive shaft
  8. Re: Unable to get any gears
    Westyman Guest
    Reported as new drive shaft, not sure which side, my daughter didn't ask. Repair with part is about £550 inc VAT. For info, car is coming up 5 years old, done 86k and always been used as domestic rather than commercial.
    Is it likely the other side will go bang too?
    Oh! And thanks for f/b.
  9. Re: Unable to get any gears
    Oct 2007
    Hi It has only been the right side so far.The left and right consruction is a bit different
  10. Re: Unable to get any gears
    Westyman Guest
    That's some comfort, thanks.
    I guess that the system is asymetric in common with many vehicles' installation.
  1. Help A3 Unable to select Reverse Gear
    By avitmark in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-11-2011, 12:10 AM
  2. Unable to clear Temp Sensor fault
    By herby0001 in forum VCDS - General Questions
    Last Post: 28-08-2008, 07:07 AM
  3. Unable to switch off ECONO light on A4
    By AndySol in forum Audi A4 - Archive Topics
    Last Post: 03-02-2008, 11:36 AM
  4. Bora leaking. Unable to find location HELP
    By redtony in forum Bora - 1998 - 2005
    Last Post: 14-07-2007, 02:10 PM
  5. Passat unable to open door
    By Fibreron in forum Archive posts
    Last Post: 18-11-2006, 06:20 PM
