Thread: Missing battery cover / WATER!?!?!?
Results 1 to 10 of 12
  1. Missing battery cover / WATER!?!?!?
    Jan 2008
    Yorkshire
    A friend of mine pointed out that I don't have the cover that tidies up the top part of the engine across the battery. The long plastic over that runs from left to right.
    I had no idea about this and peered in.
    The battery is sat in an inch of water along with all other pipes etc that runs along that part of the engine.
    It's just like a big sealed bowl.
    Should there be water in there? There isnt anywhere for it to drain.
    Does the cover ensure water doesnt flow down from the window and into this section?
    Cheers.
  2. Re: Missing battery cover / WATER!?!?!?
    There are 2 drain holes at the bottom of this bay that have probably become bunged up. You need to clear these out otherwise that water will eventually find its way into the car and flood your ECU. I know because its just happened to me about 4 weeks ago and i'm still trying to sort it out.
    I had to remove the battery to get to the bungs.
    good luck.
    (hope someone replies to my question this quick!!)
  3. Re: Missing battery cover / WATER!?!?!?
    Jan 2008
    Yorkshire
    Cheers Joe!!!!!!!!!!!
    When I disconnect the battery to look underneath will this affect anything with the A4?
    ECU/TRIP/ALARM etc etc
  4. Re: Missing battery cover / WATER!?!?!?
    Mine is a 98' A6. When I disconected the battery no alarm went off but I have had to get my ECU re programmed. I'm not sure if that is because of the water that got into it or because of the battery. Audi mechanic said it was the battery but seems a bit excessive from just disconnecting it.
    cheers
  5. Re: Missing battery cover / WATER!?!?!?
    Mar 2007
    mines missing this bit too!! ill check mine out for a padding pool tomorrow and get the part number for the cover too and then post it up.
    Karlos
  6. Re: Missing battery cover / WATER!?!?!?
    Dec 2006
    Newport South Wales
    got a cover a while back. cant remember exact price but not expensive. you need the battery cover also. you remove existing piece on left to get new one in. £17 i think
    sean
    recently picked up q5 special edition. Kept a4 b8.
  7. Re: Missing battery cover / WATER!?!?!?
    Nov 2008
    Quote Originally Posted by Audi_Convert View Post
    will not affect any of these,but all your windows will need coding in,you may have lost all your radio stations,you may have not,Just double check that.
    about the windows,all you need to do to code them in...is put each window all the way down hold each button for a couple of seconds then they should come all the way back up on there own without stopping.
    cheers
    Joe
  1. Battery Bay Cover
    By n_c in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-05-2009, 10:39 PM
  2. Missing Cover under bonnet.
    By rkrk in forum Golf MK4 - 1999 - 2004
    Last Post: 04-09-2008, 11:42 AM
  3. Question Missing engine cover?
    By KAS-1 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-07-2008, 03:07 PM
  4. A4 (B6) Battery Cover?
    By vad921 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-07-2007, 11:01 AM
