How would you know if your either your Brake servo or Master cylinder is not working properly? I understand that the servo helps you to brake by creating a vacuum etc. but if your brake is working correctly with the proper force when you apply pressure then it should be working fine?
What about the Master cylinder role in this? When do you know it's damaged?
Last, can a damaged Servo or Master cylinder create problems with your clutch system as the brake fluid is what lubricates your clutch, isn't it?
thanks
