Quote Originally Posted by Karl View Post
the bulb you need is a H7 bulb, replace them in pairs! as you will get wony lights.
as for the fitting thats all worng, I did my dipped and full beams this morning in about 15mins! its dead easy!!! the only tools you need is a X head screw driver to remove the air intake on the rh side.
unscrew the 2 small screws on the front pannel that hold the air intake in place, then pull up out of the air box and then rewards to remove from the grill area.
then undo the cover over the back of the light, hold the black connector and twist to pop the top of the bulb out and then remove the bottom - you will understand when you see it - then draw the bulb out, replace with the new one - DO NOT touch the bulb!!! - then refit which is the reverse, put the bottom back in first and the tilt to clip the top in.
then refit the cover on the back of the unit.
this is also covered in the drivers hand book,
Hi which way is the tab supposed to be facing on the bulb thanks
