Thread: golf mk3v 1.9 tdi 1993 hunting at idle
  1. golf mk3v 1.9 tdi 1993 hunting at idle
    hiya guys . got a golf here thats hunting at idle ive done the usual things new fuel filter and plastic cap on return pipe .
    have tried for codes but no codes listed
    not tried anything like egr valve as yet .
    but there is a strange thing. if you clamp the fuel feed pipe the engine settles to the propper idle speed .
    any ideas on this ? also any common faults to look out for
    engine code 1z/ahu its done 150000 so could be wear and tear
    any theories or suggestyions more than welcome ...thanks ...
    ....shuggy....ps it also keeps breaking comms with vag-com ?
  2. Re: golf mk3v 1.9 tdi 1993 hunting at idle
    Sep 2008
    Mine is huinting too and has a stutter somewhere between 1200 and 2000 revs.
    Anyone???
    Steve
  3. Re: golf mk3v 1.9 tdi 1993 hunting at idle
    Nov 2008
    I have the same engine and the same sort of mileage and have never experienced that problem.
    My guess (i said guess) is a problem with fuel delivery or injectors.
    If it was an issue with the engine itself then it's probable that the problem would be even worse at high revs.
    Probably a clogged up/blocked fuel line or injector.
    That would also explain why you aren't getting a fault code.
    And the problem would subside at higher revs because the other cylinders are having an easier time turning the engine whereas at idle a non-firing cylinder is more noticeable.
    If the blockage is only partial then it would also subside at higher revs because the speed of fuel flowing through the lines increases significantly.
    Obviously getting someone to check the lines would be best, but maybe first put some cleaner in your diesel and run it around for a few miles...
    a product like this:
    http://www.powerenhancer.co.uk/page.php/article2
    you'll probably find this does the trick.
  4. Re: golf mk3v 1.9 tdi 1993 hunting at idle
    Sep 2008
    I will eventually have a look this weekend.
    I agree it will be a prob with the fuel delivery.
    I will try my fuel pump relay first which is a common problem and then am going to swap my injectors.
    Have tried fuel cleaner and service etc but it didnt help.
    I'll post if i can sort it
    Steve
  1. 1993 MK3 1.3 - High Idle Speed
    By liamharrison in forum Golf MK3 - 1993 - 1999
    Last Post: 04-07-2008, 10:39 AM
  2. mark 2 golf hunting
    By shooey88 in forum Golf MK2 - 1984 - 1992
    Last Post: 29-05-2008, 06:05 PM
  3. 97 A4 1.8 Hunting at idle
    By rich_jc in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2008, 11:05 AM
  4. 1998 B5 - Hunting Idle after Throttle Body Cleaning
    By ectwo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2008, 05:53 AM
  5. golf mk3 1993
    By Rob C in forum Golf MK3 - 1993 - 1999
    Last Post: 25-10-2007, 09:35 AM
