Thread: Climate Control Blowin Hot Then Cold ?
  1. Exclamation Climate Control Blowin Hot Then Cold ?
    Veh - VW Golf GT TDI (2000)
    Ive just bought the above veh from a garage. The only problem is that when i put the heating on it blows hot air then cold and carries on like this.
    I was told it was fixed because he changed the thermostat in the engine this changed nothing then changed the water pump and evrything was ok
    Also when driving home a yellow coil symbol appeared on the dash and stayed on. (didnt get the vehicle manual)
    Any help please
  2. Re: Climate Control Blowin Hot Then Cold ?
    Bath, Somerset
    The coil symbol in the dash is to do with your glow plugs. It should light up for a few seconds before start up and then go out showing the glow plugs are operating but if the light stays on it means there is a problem with them...
  1. Replies: 2
    Last Post: 08-08-2008, 10:53 PM
  2. Climate Control - Cold blowing warm.
    By JezzaL in forum Audi A3 - Archive Topics
    Last Post: 04-06-2008, 05:46 PM
  3. Getting cold air on low with 08 Climate Control
    By richieb123 in forum Audi A3 - Archive Topics
    Last Post: 10-05-2008, 07:38 PM
  4. Noise From Climate Control When Cold
    By ad1966 in forum Golf MK4 - 1999 - 2004
    Last Post: 21-02-2008, 01:45 PM
  5. Coolant leak and blowin cold
    By new2vwa in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-01-2008, 04:56 PM
