Thread: WHAT DOES 'l N l' ON MILAGE LCD MEAN
  1. WHAT DOES 'l N l' ON MILAGE LCD MEAN
    Feb 2007
    WHEN I START MY AUDI THE CODE lnl FLASHES FOR A WHILE ON THE MILAGE LCD. DOES ANYONE KNOW WHAT THIS STANDS FOR?
    CHEERS
    JOE
    Canada
    Can you tell us the model and year of your audi a4. should be able to help then
    Feb 2007
    It is a 1997 1.6SE Avant
  4. Talking 1 in 2
    NORTHAMPTON
    HI.I HAVE AN A4 1996 2.6 SE AND THE CODE THAT FLASHES UP FOR ABOUT 60 SECS MEANS ITS DUE SERVICE/INSPECTION.IT STOPS AFTER THAT TIME AND REVERTS BACK TO TRIPMETER MODE.IF IT ANNOYS YOU PRESS THE TRIP RESET BUTTON AND IT WILL STOP UNTIL YOU RESTART THE CAR AGAIN AND DO THE SAME THING.ALSO SHOWN ON THE DISPLAY IS:-OEL = OIL CHANGE, IN 1 = INSPECTION, IN 2 = ADDITIONAL SERVICE WORK. IF "DEF" APPEARS IN THE DISPLAY PERMANENTLY THEN THE FAULTS SHOULD BE SORTED ASAP.THE DEALER WOULD RESET THESE CODES AFTER DOING THE WORK/SERVICING BUT ANYONE WITH VAG-COM WOULD BE ABLE TO RESET THESE FOR YOU.
    REGARDS PINTPOTTER
    Feb 2007
    Cheers many thanks
  1. New guy milage quiery re:TDI's, advice needed!!!
    By teccyjim in forum New Member Introductions
    Last Post: 04-05-2007, 12:35 AM
  2. High Milage Passat 'a good buy' ?
    By stevenm in forum Passat - Archive Topics
    Last Post: 09-06-2006, 12:56 PM
  3. High milage scirocco
    By TomLaw in forum Scirocco - Corrado
    Last Post: 03-12-2005, 07:13 PM
