Thread: stereo wiring woes
Results 1 to 10 of 11
  1. stereo wiring woes
    Oct 2007
    Hi All, I have a 97 TDi GL that is a great car but for 1 problem. The stereo fitted to it drains the battery over 4 days (removing stereo battery lasts for weeks). I also have a 95 GTI that I had the stereo in that didn't drain the battery. Any ideas on what the diferent wirings could be before I trawl thro' loom? Simon
  2. Re: stereo wiring woes
    Dec 2006
    Manchester
    They might be the same... i'm not sure when VW started putting ISO connectors in as standard....
    Best way is to have a look. The wiring diagram will be on the stereo anyway
    Nick
    1.9 tdi PD 100 Bora
    110cc pitbike, 4 speed semi-auto
    110cc Off road buggy, 4 speed semi-auto
  3. Re: stereo wiring woes
    Oct 2007
    OK will look. Both cars do have ISO connectors but diesel seems to feed something when ignition is off. Simon.
  4. Re: stereo wiring woes
    Birmingham
    Should be the same, my '96 has an ISO connection for the head unit.
    I'm sure I've read a post that somebody put up about their head unit draining their battery whilst turned off with the ignition, I'm sure it said they started turning it off with the button before they got out (rather than letting the ignition switch it off) and it cured the battery drain.
  5. Re: stereo wiring woes
    Dec 2006
    Manchester
    It's possibly a faulty stereo that has a short. I'd try the "95" stereo in the "97" car and see if the problem persists....
    Good luck!
    1.9 tdi PD 100 Bora
  6. Re: stereo wiring woes
    Oct 2007
    Thanks guys, Just to clarify the connections for the stereos are the same and I had both cars running the same stereo fine but the wiring must be different as the GTI stood for 2 weeks without running flat with this stereo fitted. The only difference was that I didn't have the 6 CD changer fitted to the GTI. Could it be the changer running down the diesel I wonder?
  7. Re: stereo wiring woes
    I have a problem that I changed over the wires red and yellow now when the key is in ignition and turned before starting up the headunit starts up... but when the car turns on the headunit turn off and says See Ya LOL someone help meee =D
  8. Re: stereo wiring woes
    When I changed the wires over it was more off a success as the Headunit didn't work aswell... it turned on and off when it wanted to,
  9. Re: stereo wiring woes
    Birmingham
    Aimed at haider (should have quoted really).
    I think the fuse in the fusebox must have gone. It sounds like the stereo's getting a perm when the ignition's turned on (the wires need switching back round again) and cutting out the supply as it as the car's starting.
    In short turn the wires back round again (red and yellow) and replace the fuse for the stereo if I'm right.
  10. Re: stereo wiring woes
    i have 2 fuses one at the back of the headunit which I am replacing and one at the fuse box?
  1. Replacement Stereo Woes!
    By damoyoung in forum 80 - 90
    Last Post: 23-07-2009, 09:06 AM
  2. stereo wiring
    By taztaz in forum Bora - 1998 - 2005
    Last Post: 28-04-2008, 08:25 AM
  3. mk4 golf stereo wiring
    By lawto in forum New Member Introductions
    Last Post: 18-03-2008, 09:18 PM
  4. Golf Mk3 Gl Stereo Wiring
    By repta in forum Golf MK3 - 1993 - 1999
    Last Post: 15-02-2008, 01:24 AM
  5. stereo wiring harness
    By otis_b in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-09-2007, 02:20 PM
