Thread: Going into Hibernation
Results 1 to 10 of 14
  1. Unhappy Going into Hibernation
    Hi all,
    i'm just about to put my golf into long term storage,(sob,sob).
    Does anyone know what i should do to prepare it?
    Any ideas would be greatly appreciated.
    Jay.
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    disconnect battery
    Lift off the 4 wheels
    Close vents
    Car cover over the top
    Umm, and all being well it will restart when it's unsurfaced again.
    Jason - Rather mad Skoda Fabia driver.... Odd whiff of diesel coming from him.
    260bhp Skoda Fabia TDI Dyno Run
    http://www.youtube.com/watch?v=9BvjJjL7Z50
    315bhp Skoda Fabia TDI Dyno Run (2013)
    http://www.youtube.com/watch?v=TOE4nbT5NGY
    Nov 2006
    derbyshire
    Leave the handbrake off and stick it into first. Prevent's handbrake siezing on.
    Canada
    Right, this is what i would do,
    Change the oil to reduce deteriation in the engine, dirty oil has acid deposits in it.. change the brake fluild for the same reason.
    Change the water and put in new anti-freeze.
    Take the battery out, don't store it in the car, fire hazard
    Get the car waxoiled underneath and injected into the sills etc.
    Get some Big silica gel bags to keep the interior dry. I've seen them advertised in Practical Classics. Should be able to find them on the web.
    I don't know the conditon of the car but if you have any chips or little bits of rust treat them.
    The previous advice about the tyres is what i would do and the leave the hand brake off.
    Make sure it drys when you store it.
    Finally remember, if the garage appears to be dry, there is still humidity as we live in england.
    Thinks that it, but cars do seems to go down hill without moving at all
    Rob
  5. Re: Going into Hibernation
    Aug 2007
    I'm about to do this to my '99 A3, and got another question -
    will the alarm work as is when putting the battery back in after 6 months say? As in, I can disconnect and reconnect the battery in a few months time and not worry about anything electrical going haywire?
  6. Re: Going into Hibernation
    Pembrokeshire
    22 Post(s)
    i would also take the spark plugs out (once in position in garage), and squirt liberal amounts of engine oil into the bores. then turn over a few times by hand. replace plugs to prevent anything dropping down. when its time to restart it, remove plugs and suck out any remaining oil using an oil extractor, or spin over on the starter to squirt it out. replace plugs, turn over a few times by hand to ensure it wont hydraulic, then fire her up. it will smoke like crazy for a while, but you wont have rusty bores. also, whilst in storage, i would turn it over by hand every so often.
  7. Re: Going into Hibernation
    Mar 2008
    High Wycombe
    Why does it need to go into long term storage? Unless you're going away for a long time, can't you keep driving it? If you are going away, can you get a family member to drive it once a week for you?
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  8. Re: Going into Hibernation
    Tyldesley, Manchester, UK
    Quote Originally Posted by Jay View Post
    Hi all,
    Jay.
    Long Term? Months or years? Onzarob's suggestion would be years I guess. For say six months just chock the wheels leave the handbrake off, put a Optimate battery conditioner (or similar on) and you might fill the tank to the brim and add a cover if you wish, mine is stored like that in the garage over the Winter, though I do not fill the tank.
    Driving an old classic car I have read many ways to store them. I can only speak from personal experience.
    One German, Two Italian.
  9. Re: Going into Hibernation
    May 2008
    I wouldn'd do that if it's got a catalyst! The potential problem which oil down the bores would prevent is rusting in the bores and piston rings. "Liberal amounts" of unburnt engine oil deposited on your catalyst could prove very expensive in future. Ideally just leave engine as run and turn it over a few times by hand every month. Otherwise use a small amount of lube as suggested and make sure you replace the plugs for storage or bore rusting will be certain!
  10. Re: Going into Hibernation
    Canada
    I wonder if the OP's car is now out of storage...he may have some tips???
    My post was along time ago
