Thread: Tyre size info
Results 1 to 10 of 17
  1. Tyre size info
    Feb 2007
    Poole
    Hello, am new, and not an Audi owner, although do own a quality German vehicle
    Just been lumbered with a set of 215/55R16 tyres.
    Neighbour has an Audi A4 estate circa V plate I think (private plate) fitted with 205/55R16 tyres.
    Anyone use the 215's, or know if they'll fit? Clearance looks fine on rear, front maybe too close to strut - reason I've got myself lumbered with these tyres
    Also, a mate has a P plate Audi A4 1.8 turbo (150 bhp model).
    Anyone tell me the size of tyres these use? He can't, he lacks sense...
    Many thanks, Justin
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    The difference will be marginal between 205 and 215.
    Essentially the 205/55 means a 205mm wide track, and the profile is 55% (i.e around 115mm?) Going to 215mm means this profile will just go up by about 5%, i.e around 5mm, and 10mm overall bigger diameter, which means a 31.4mm difference over the rolling radius I think. The average rolling radius of a tyre that size is well over 2 metres I think, so pretty small %%s.
    "within tolerances" is a phrase I like to use.
    Jason - Rather mad Skoda Fabia driver.... Odd whiff of diesel coming from him.
    260bhp Skoda Fabia TDI Dyno Run
    http://www.youtube.com/watch?v=9BvjJjL7Z50
    315bhp Skoda Fabia TDI Dyno Run (2013)
    http://www.youtube.com/watch?v=TOE4nbT5NGY
    Feb 2007
    Poole
    Thanks for reply.
    Tried to fit them to a calibra that runs 205/50 tyres, I banked on the width increase, but not the profile - the 2 combined meant tyre was too close to strut cup. I thought, as you say 'marginal' but was too close. Such little difference, but no room for the increase.
    On neighbours car the front tyres are pretty close to strut cup, and wouldn't like to say if the extra 10 width would be do-able.
    Good info though, but it's the physical aspect (tyre to strut) I'm concerned about - as you say within tolerance speedo wise, and would make it more accurate considering the built in overead.
    Be nice if someone had these on their estate really!
    Sure the Audi A4 1.8 sport thing will have 215's, is sportier, and remember them not looking too low profile at all.
    Thanks for your help
    Oct 2005
    http://www.miata.net/garage/tirecalc.html
    Simply plug the current tyres in the first boxes and the new ones in the second.
    As for fit, they should fit fine. I have 205/60s on my 15s (ET 35ish) and they stand well away from the struts.
    P Plate A4 is tricky to tell.
    205/60/15 is the Euro standard (sometimes you'll find 195/65/15)
    205/55/16, 225/45/17 and so on.
    Feb 2007
    Poole
    Cheers.
    All I need to know is whether they will safely fit - clear the strut, speedo etc is no concern.
    May 2006
    I say they will as you're not altering the width by much (a mere cm) and the profile is more or less the same too.
    I went from 205/40 to 215/40 and whilst 40% is less than 55%, you cannot really tell I have different tyres on the front to the back. The difference on the road is much better though - could be because the front is a better model Toyo tyre too though.
    Feb 2007
    Poole
    Quote Originally Posted by devonutopia View Post
    That's what I thought with the calibra...
    I am of same opinion as you, but considering what happened with the calibra want someone to tell me they are running 215/55's
    Nov 2006
    Swampyland, UK
    OK, OK, here are a couple more sites, which get info on offsets and clearance:
    http://marksink.com/tire_wheel_offset/offset.html
    http://marksink.com/tire_wheel_offset/tires.html
    This Venom one is handy for differing ratios too
    http://www.venommotorsports.com/libr...calculator.asp
    Rgds
    May 2006
    Look up "car tyre bible" - There's a formula thing in there where you select the sizes of the two tyres in dropdowns, and it works out diameter, RR % differences.
  10. Exclamation A4 Tyres
    NORTHAMPTON
    Hi,im Not Saying Anyone Is Incorrect Firstly.all Im Going To Say Is 3 Weeks Ago I Was In The Same Boat With My '96 V6 A4.had Got A Set Of 16" Audi Alloys With No Tires On To Replace The Bland 15" Se Alloys.now I Was Wanting The 205/55/16 Originally But Asked About The 215's And Was Told "no Way It Will Just Cause More Problems Than Its Worth And We Wouldnt Want To Do The Work For You Even Though We Would Make More Money On The Bigger Tyres Due To Safety Issues".
    Now Read What You Will Into That But I Was Glad For There Honesty As They Seemed To Think There Was A Safety Issue And It Was Easier On My Pocket Anyway!exactly What The Issues Were I Dont Know.
    I Know It Doosnt Give Any Deffinate Answers But Just Thought I Would Let You Know.
    Regards Pintpotter
  1. passat estate 1.9 td 1994 correct tyre size
    By swonny2 in forum Passat - Archive Topics
    Last Post: 04-06-2007, 09:06 AM
  2. Wheel size and tyre fitment
    By chasw7 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-03-2007, 10:51 AM
  3. Maximum wheel/tyre size on A4?
    By Mark A4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-03-2007, 10:58 PM
  4. Passat tyre size
    By ImolaOrange in forum Passat - Archive Topics
    Last Post: 17-12-2006, 10:58 AM
  5. What size alloys?
    By C J in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 11-02-2005, 06:53 PM
