Thread: Replacing K03s turbo with K04
  1. Replacing K03s turbo with K04
    Aug 2008
    This would be on a Audi A4 1.8t quattro sport. Is it a straight forward swap, as i was reading something in the golf magazine and you can apparently get 300 bhp by just swapping and remapping.
  2. Re: Replacing K03s turbo with K04
    Birmingham
    I think you need a front mounted intercooler aswell to get near the 300bhp mark.
  3. Re: Replacing K03s turbo with K04
    Aug 2008
    Well it also stated you could get up to 345 bhp if you fitted a free flow cat downpipe but no mention of a replacement intercooler.
    My main issue though is, Is it a straight swap?
  4. Re: Replacing K03s turbo with K04
    Birmingham
    If you read the feature again it says that it's a lot of work on your engine for a little gain, the turbo manifold is restrictive and you won't see much gain. For around 300bhp on your engine you need a front mount and either an IHI roller bearing turbo or a Garrett GT2860RS turbo. Unfortunately they both weigh in at about £4000 fitted. Apparently though an earlier non variable valve 20v cylinder head with your current turbo works very well and can see good gains.
  1. How To Replacing a Turbo on a Mk 4 TDi 130
    By hat 004 in forum Golf MK4 - 1999 - 2004
    Last Post: 14-07-2008, 03:23 PM
  2. k03s n75 charge pipe
    By OctavianC in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-06-2008, 11:29 AM
  3. Please Help Smoke on start up after replacing turbo?
    By stevee_p in forum Golf MK4 - 1999 - 2004
    Last Post: 12-05-2008, 07:04 PM
  4. Error code 17963 after replacing turbo
    By mmm777 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 09-10-2007, 11:09 PM
  5. replacing the turbo on TDi 110
    By teedeeAye in forum Golf MK4 - 1999 - 2004
    Last Post: 26-09-2007, 05:15 PM
