Most Recent Vehicle Details and Test Summary applicable to this test number.
Registration mark: R** ***
Make/Model: AUDI / A4 1.9 TDI SE AUTO
Colour: SILVER
VIN/Chassis No: WAUZZZ8DZVA******
Approximate date of first use: 01/08/1997
Type of fuel: Diesel
Date of test: 17/09/2008
Certificate issued (Pass)
Odometer reading: 113,603 Miles
Test number: 494141668272
Test expiry date: 16/09/2009
Full Test History, starting with first recorded vehicle and test results
Colour: SILVER
VIN/Chassis No: WAUZZZ8DZVA256163
Type of fuel: Petrol
Date of test: 06/09/2006
Certificate issue refused (Fail)
Odometer reading: 90,732 Miles
Test number: 394579846250
Test station name: PALACE MOTORS LTD
Test station number: 9318B8
Test station telephone number: 02083407902
Test class: IV
Reason(s) for refusal to issue Certificate
Nearside Front Brake hose seriously damaged (found during steering lock to lock check) (2.2.D.1b)
Offside Front Brake hose seriously damaged (found during steering lock to lock check) (2.2.D.1b)
Offside Stop lamp not working (1.3.2a)
No Advisory Notice issued
Date of test: 07/09/2006
Test number: 250590156216
Test class: IV
Test expiry date: 06/09/2007
Date of test: 07/09/2007
Odometer reading: 106,212 Miles
Test number: 853940857243
Test station name: OXNEY GARAGE
Test station number: 0563A4
Test station telephone number: 01245420149
Test class: IV
Offside Front position lamp(s) not in good working order (not working) (1.1.4a)
Nearside Front Track rod end ball joint has excessive play (2.2.B.1f)
Nearside Rear Tyre worn close to the legal limit (4.1.D.1)
Both nearside and offside Rear wheel bearing has slight play (2.6.2)
Oil leak
Change of details
Make/Model: AUDI / A4 1.9 TDI SE AUTO recorded at time of test on 07/09/2007
Type of fuel: Diesel recorded at time of test on 07/09/2007
Date of test: 08/09/2007
Odometer reading: 106,238 Miles
Test number: 241221857271
Test class: IV
Test expiry date: 07/09/2008
Odometer reading: 113,602 Miles
Test number: 932671468219
Test class: IV
Nearside Headlamp not in good working order adversely affecting beam image (1.2.4a)
Offside Headlamp not in good working order adversely affecting beam image (1.2.4a)
Offside Front constant velocity joint gaiter split (2.5.C.1a)
Both Rear wheel bearing has slight play (2.6.2)
Offside Rear Tyre worn close to the legal limit (4.1.D.1)
Non obligatory mirror damaged
Air bag light on
Test class: IV
Air bag light on
