Thread: Oil leak rocker cover
  1. Oil leak rocker cover
    May 2008
    My car is going through the mill at the moment. See seperate thread on damp carpets.
    Anyway Ive got a slow but steady oil leak from the rocker cover. The oil appears all along the lower edge of the joint. It is dripping down onto cat and burning off.
    My techy brother took it apart and refitted using silicone gasket material. We did however reuse the gasket which looked sound.
    I did notice that there was a semi circular cutout and thought this might be a weak point. My local VW Inde garage has also tried and failed to solve.
    Any thoughts please.
    David
  2. Re: Oil leak rocker cover
    Sep 2008
    Birmingham
    Fit a new original vw gasket this will come with the rubber half moon and if it's torqued down nice and equally you shouldn't have any more problems.
  3. Re: Oil leak rocker cover
    134 Post(s)
    2022 Post(s)
    Year and engine?
  4. Re: Oil leak rocker cover
    May 2008
    The engine is a 1.8 20v Turbo 1998 now with 120,000 on the clock.
  5. Re: Oil leak rocker cover
    134 Post(s)
    2022 Post(s)
    If the gasket has been replaced and it still leaks there are two common possibilities, one is that it has the early cover which was prone to warping (it changed in 98) and the other is that the breather system is blocked and causing excess crankcase pressure which is forcing the oil out and sludge build up is a terrible problem on the 1.8T, often leading to a destroyed engine and turbo.
  6. Re: Oil leak rocker cover
    May 2008
    Can anyone give me clear instructions on where this breather tube is and what I do to it. Thanks.
  7. Re: Oil leak rocker cover
    134 Post(s)
    2022 Post(s)
    It isn’t necessarily the tube but the whole system that becomes blocked. PM me your email and I will send you some diagrams.
  1. Change rocker cover gasket?
    By Boratslovechild in forum Golf MK4 - 1999 - 2004
    Last Post: 05-05-2013, 11:12 AM
  2. Valve/Rocker Cover Gasket Change (2.8)
    By joncrowe in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-04-2008, 06:50 PM
  3. Rocker cover gasket?
    By tom3011 in forum Golf MK4 - 1999 - 2004
    Last Post: 27-03-2008, 02:21 PM
  4. Help needed - removing a threaded bolt on Rocker cover
    By bio10155 in forum Archive posts
    Last Post: 10-02-2008, 09:09 PM
  5. Rocker Cover Gasket
    By Gazz in forum Audi A4 - Archive Topics
    Last Post: 11-01-2007, 05:01 PM
