Thread: aftermarket stereo
  1. aftermarket stereo
    Dec 2007
    Hi All
    I am trying to fit an aftermarket stereo(ripwave) with a standard ISO connection to replace my concert II. I have bought the correct facea and am ready to go but the problem i have is when i plug in the audi iso connectors into the new stereo iso connection im not getting any power when i turn on ignition on , i have checked that im putting the connectors in ok but still no joy, also i have a ck7w nokia bluetooth car kit connected to my concert stereo but noticed the new stereo does not have a mute connector so am wondering will i have to manually turn the stereo down should i manage to get everything connected and working. My car is a 2003 A4 1.9TDI
    any help on this is greatly appreciated
    regards,
    Nigel
  2. Re: aftermarket stereo
    Oct 2007
    Tiptree, Essex
    Quote Originally Posted by nmgartland View Post
    Hi All
    ............... but the problem i have is when i plug in the audi iso connectors into the new stereo iso connection im not getting any power when i turn on ignition on , i have checked that im putting the connectors in ok but still no joy, also i have a ck7w nokia bluetooth car kit connected to my concert stereo but noticed the new stereo does not have a mute connector so am wondering will i have to manually turn the stereo down should i manage to get everything connected and working. My car is a 2003 A4 1.9TDI
    regards,
    Nigel
    A fellow forum member, "m40mfa", is asking the same question on radio power, check out he following thread too........
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=49139
    FYI: The Audi "Power" ISO connector has the following connections:
    Connector III:
    Pin 1 : Bose Signal
    Pin 2 : Alarm Ground
    Pin 3 : K-Line
    Pin 4 : not connected
    Pin 5 : not connected
    Pin 6 : not connected
    Pin 7 : +12v (Constant 12v supply)
    Pin 8 : 0v Main Ground
    **** NOTE: Be careful not to feed any signals back to the car wiring through Pin 3, "K-Line" since this is a diagnostic connection. Will interfere with VAG-COM and Audi diagnostic systems - check out this link....
    http://www.ross-tech.com/vag-com/aftermarket-radio.html
    Phone Muting:
    if your new stereo does not have a phone muting input then you have three obvious choices:
    1. Turn don the stereo manually.
    2. Make a muting interface with a relay to mute the speakers.
    3. Purchase a 3rd party Bluetooth phone kit which does this for you like a Parrot CK3100 - this will mute your stereo via standard ISO connectors regardless if the stereo has this function. (Note this kit also requires a switched +12v to work as per your 3rd party radio.)
    Hope this helps?
    A4 3.0 Quattro Sport Tiptronic (51) Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits: S-Line Bumpers, Amb F&R LEDS, Xenon HID's (slimline) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Parrot CK3100 BT, RNS-E + Video i-pod + Aux inputs, Rear PDC, ISO-FIX, VCDS HEX+USB+CAN (VAG-COM)
  3. Re: aftermarket stereo
    Dec 2007
    Hi Woorlord, many thanks for your reply.
  4. Re: aftermarket stereo
    Birmingham
    You'll have to take an ignition live from elsewhere in the car, the factory unit uses canbus (low voltage) to switch it on.
    There should be a thick black wire in the main loom behind your glovebox, I'd bridge off that one.
  5. Re: aftermarket stereo
    Dec 2007
    Hi Guys,
    as regards the power problem do i just disconnect connect the +12V from pin 7 on my audi connection and connect it to the the +12V input pin on the new stereo, sorry for the silly questions but this is the first time i have ever done anything like this,
    thanks in advance
    Nigel.
  6. Re: aftermarket stereo
    Oct 2007
    Tiptree, Essex
    Hi Guys,
    thanks in advance
    Nigel.
    Audi ISO-Connector III-Pin 7 is a +12v always ON supply - this can be connected to your radio permanent +12v supply which is normally used to retain the radio's memory settings on 3rd party units.
    You need to supply +12v to the switched live input of the radio - this is normally fed via a switched +12v ignition supply if you want your radio to switch on/off with the ignition. However, you could connect a permanent +12v feed to the switched input of the radio. Be aware that your radio could be left on after ignition key removal and give you a flat battery! This connection is your choice.
    For your radio to work with minimal wiring modifications connect the +12v constant supply from Pin 7 to both the permanent (memory) +12v supply and the switched +12v supply of the radio. Remember to turn your radio off when exiting the car!
    With regard to the Nokia BT handsfree kit you will want this to be on a switched ignition supply otherwise the BT connection will try and be maintained after you remove the igtn key. It would be much better that when you switch the ignition on the BT connects to your phone automatically and when the igtn key removed, the BT connection auto disconnects. Again leaving this on connected to a permanent supply will flatten your vehicle battery!
  7. Re: aftermarket stereo
    Dec 2007
    Thanks guys for all the replies, will have a go and let you know how I got on,
    Nigel
  8. Re: aftermarket stereo
    Is there an aftermarket stereo that will work with the dash display to show the radio station that is on?
  9. Re: aftermarket stereo
    Dec 2007
    Hi all, Just to let you know I chickened out on the aftermarket stereo, far too much hassle. Bought an Ipod X-carlink adapter, took 20 min to fit and works perfectly with phone. Thanks for all your replies.
    Nigel
  1. Aftermarket stereo
    By trigger301 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-04-2008, 01:02 PM
  2. Aftermarket Stereo for Newbie
    By davyb69 in forum Audi A3 - Archive Topics
    Last Post: 23-04-2008, 12:36 AM
  3. Has anyone replaced their stereo for an aftermarket one?
    By james_tiger_woo in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-04-2008, 09:18 AM
  4. aftermarket stereo problems
    By pablopeebles in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-01-2008, 04:51 PM
  5. 80 Estate aftermarket stereo problem
    By Cabe in forum 80 - 90
    Last Post: 01-01-2008, 08:07 PM
