Re: aftermarket stereo –
29-09-2008,03:03 PM
Originally Posted by
nmgartland
Hi Guys,
as regards the power problem do i just disconnect connect the +12V from pin 7 on my audi connection and connect it to the the +12V input pin on the new stereo, sorry for the silly questions but this is the first time i have ever done anything like this,
thanks in advance
Nigel.
Audi ISO-Connector III-Pin 7 is a +12v always ON supply - this can be connected to your radio permanent +12v supply which is normally used to retain the radio's memory settings on 3rd party units.
You need to supply +12v to the switched live input of the radio - this is normally fed via a switched +12v ignition supply if you want your radio to switch on/off with the ignition. However, you could connect a permanent +12v feed to the switched input of the radio. Be aware that your radio could be left on after ignition key removal and give you a flat battery! This connection is your choice.
For your radio to work with minimal wiring modifications connect the +12v constant supply from Pin 7 to both the permanent (memory) +12v supply and the switched +12v supply of the radio. Remember to turn your radio off when exiting the car!
With regard to the Nokia BT handsfree kit you will want this to be on a switched ignition supply otherwise the BT connection will try and be maintained after you remove the igtn key. It would be much better that when you switch the ignition on the BT connects to your phone automatically and when the igtn key removed, the BT connection auto disconnects. Again leaving this on connected to a permanent supply will flatten your vehicle battery!
A4 3.0 Quattro Sport Tiptronic (51) Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
Retrofits: S-Line Bumpers, Amb F&R LEDS, Xenon HID's (slimline) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Parrot CK3100 BT, RNS-E + Video i-pod + Aux inputs, Rear PDC, ISO-FIX, VCDS HEX+USB+CAN (VAG-COM)
