Thread: help with following fault codes please
  1. Exclamation help with following fault codes please
    Aug 2008
    hi i have an 1995 audi a4 and have done a scan of it with vagcom and a shareware version of software and it comes up with the following faults:
    control module part number;8d0907557c
    componentand/or version : 1,8l r4/5v motr hs d05
    software coding :04001
    work shop code : wsc 00000
    5 faults found:
    18010 - power supply terminal30: voltage too low
    p1602 - 35-10 - - - intermittent
    17978 - Shareware version. to decode all dtcs
    p1570 -35-10 - please register/activate - intermittent
    17733 - Shareware version. to decode all dtcs
    p1325 -35-10 -please register/activate - intermittent
    17735 - Knock-control: Cyliner 3: Regulation limit exceeded
    p1327 -35-10 - - - - intermittent
    16705 - Shareware version. to decode all dtcs
    p0321 - 35-10 - please register/activate - intermittent
    and also i have the following come up as well :
    control module part number : 8a0959655b
    component and/or version : Airbag v Audi D00
    software coding : 00766
    Work shop code : wsc 06311
    1 fault found:
    00532 - supply voltage B+
    07-10 - signal too low - intermittent
    does any body have any idea what all these codes are telling me and how will i sort them out as i do not know what the are tell me so any help would be greatly appreciated
  2. Re: help with following fault codes please
    Dec 2007
    Suffolk
    They are all intermittent so clear them and see which ones come back. It has had a flat battery at some point by the look at them codes.
    Is there a running problem?
    Code meanings:
    18010 - power supply terminal 30: voltage too low
    P1602 - 35-10 - - - intermittent
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - - intermittent
    17733 - Knock-control: Cylinder 1: Regulation limit exceeded
    P1325 - 35-10 - - - intermittent
    17735 - Knock-control: Cylinder 3: Regulation limit exceeded
    P1327 - 35-10 - - - intermittent
    16705 - Engine Speed Sensor (G28): Implausible Signal
    P0321 - 35-10 - - - intermittent
  3. Re: help with following fault codes please
    Aug 2008
    Quote Originally Posted by smokey0123 View Post
    Code meanings:
    if you mean is the car having problems running then no it does not so all i have to do is clear them and see if any of them come back then i assume then if they do then what do i have to do then
    many thanks for your help anyway
  1. Fault codes??
    By adidasandy in forum Golf MK4 - 1999 - 2004
    Last Post: 14-05-2008, 12:44 PM
  2. ####Fault Codes#####
    By Stevebt in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-03-2008, 03:09 PM
  3. fault codes-vag
    By vw754 in forum VCDS - General Questions
    Last Post: 25-12-2007, 11:03 PM
  4. vag com fault codes
    By Dozz in forum Audi A4 - Archive Topics
    Last Post: 10-06-2007, 12:45 AM
  5. Fault codes
    By andyd118 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-05-2007, 10:27 PM
