Thread: Steering angle sensor
  1. Steering angle sensor
    How do I change the steering angle sensor on a 2004 1.9 tdi avant. Is it a garage job or can I do it. If so are there any special tools I need.
  2. Re: Steering angle sensor
    Sep 2007
    Bookham, Surrey
    I've just done mine myself. Posted the details here (https://www.vwaudiforum.co.uk/forum/s...ad.php?t=52848)
    Its not a difficult job but you do need some specialist tools as follows:
    Torx27 to get the airbag off
    Long Torx8 (buy a std one from halfords and cut the handle back)
    12mm multispline to get the steering wheel off
    Torque wrench to put the steering wheel back on to the right torque (50NM)
    4mm allen key to loosen the lower cowling
    Access to full VCDS (VAGCOM) to recalibrate the new sensor
    You don't really need to remove the dash inserts.
    **BUT don't forget to disconnect the battery before you remove the airbag**
    Garage will charge you £175 for the part plus an hours labour so nearly £300 quid.
    I just bit the bullet in the end and shelled out the £250 for the full VCDS so this job cost me more than taking it to the garage. But I figure now I have the full software, if I do one more thing its paid for itself.
    Good luck if you decide to do it yourself.
    Last edited by TheMatador; 09-11-2008 at 08:51 PM. Reason: Forgot to mention about the airbag
  1. Please Help Steering angle sensor problem
    By Spookytooth in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-02-2009, 01:59 AM
  2. steering angle
    By chris g in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 30-01-2009, 09:28 PM
  3. Can the steering column cowling be removed without removing the steering wheel?
    By rich_jc in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-04-2008, 06:48 PM
  4. angle eyes
    By papalion in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-09-2007, 03:14 AM
  5. Crank angle sensor
    By febay in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-09-2007, 11:35 AM
