Thread: timing diesel pump
  1. timing diesel pump
    hi to all when my cambelt was done the joker who done it never done it properly i have been getting error code 0550 start of injection control timing, car has no power at all been to a few people who wasted my time finally got someone to sort it out turns out the timing was out badly now that the timing has been done the car does not start as the guy who put a second hand pump on done so by adjusting the pump timing just to get it going, the power problems were still not solved my question is if the timing has been done correctly can the diesel pump be timed to run with it correctly or do i need a new fuel pump to calibarate it as the mechanic tells me he,s got the timing right but the car will not start as the pump had advanced timing to make the car run
  2. Re: timing diesel pump
    anybody that can help its driving me mad thanks
  3. Re: timing diesel pump
    london/ UK
    If the new pump is ok and it's timed properly, then it should start...What car you have ?
  4. Re: timing diesel pump
    thanks for the reply audi a4 1.9 tdi afn isn't it possible to take the pump off and then retime it according to the timing belt sorry im not a mechanic so dont know much
  5. Re: timing diesel pump
    london/ UK
    You dont need to remove the pump when timing the pump with regards to the engine. You should set the engine at TDC, then reset the pump and fit the locking pin on the pump, then refit the belt on the camshaft, while thats held with a locking plate, turn the tensioner clockwise until the notch lines up with the mark then turn the engine few times by hand couple of times... There are a few special tools to use but, i use an old driveshaft bolt to hold the pump sprocket, a spanner to lock the camshaft and i line the mark on the flywheel with the edge of the bell housing ! You will need a drift to remove the sprocket off the camshaft as well.
  1. how to check static pump timing with vag-com?
    By aniesigh in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-03-2008, 09:08 PM
  2. LT35 2.5 5cyl pump timing
    By Darren Nesbitt in forum The Commercial Range
    Last Post: 01-11-2007, 02:43 PM
  3. fuel injection pump timing T4 1.9 TD ABL
    By Volkner in forum The Commercial Range
    Last Post: 18-09-2007, 10:16 PM
  4. £300 for timing belt and water pump ??
    By rickgti in forum Golf MK4 - 1999 - 2004
    Last Post: 07-09-2007, 05:15 PM
  5. Timing belt, water pump, MAF - MK4 GTi
    Last Post: 29-08-2007, 03:02 PM
