Thread: Whats wrong with my car?
Results 1 to 9 of 9
  1. Whats wrong with my car?
    Sep 2008
    I've got the engine management light on on my dash board. I have done a diagnostic test to find out what the faults were. Here are the faults.
    P0444 - Evaporative Emission Control System Purge Control Valve Circuit Open.
    P0038 - O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
    I have changed the o2 sensor and reseted the engine management light but it still comes back on and says the same thing
    "P0038 - O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
    Anyone know what the problem is?
    My car is a VW GOLF 1.6 16v 2002
  2. Re: Whats wrong with my car?
    134 Post(s)
    2007 Post(s)
    Which engine code?
    Does the EVAP code come back?
  3. Re: Whats wrong with my car?
    Sep 2008
    Which engine code?
    Here are the codes?
    P0038 - Heater control Circuit High ( Bank 1 Sensor 2)
    P0170 - Fuel Trim Malfunction (Bank 1)
    Does anyone know what any of them means?
  4. Re: Whats wrong with my car?
    134 Post(s)
    2007 Post(s)
    What is the engine code AZD, BAD or BCB?
    You have faults there with both lambda sensor heaters, S1 = sensor 1 (pre cat), S2 = sensor 2 (post cat) and that explains the fuel trim issue. Both S1 and S2 are on the same circuit as the EVAP valve so I suspect you have fault in the circuit which has blown fuse 43 on the fuse board on the side of the facia.
  5. Re: Whats wrong with my car?
    Sep 2008
    Hi, Thanks for your help. The engine Code is AZD, I have changed sensor 1. I have checked all the fuse, all of them seem to look fine.
    Is sensor 1 the one in front of the cat or is it the one before it.
  6. Re: Whats wrong with my car?
    134 Post(s)
    2007 Post(s)
    Check there is power to and from the fuse with a test light or multimeter, do not depend on a visual check, three of your fault codes point to a power failure on that circuit. As for which sensor is which, read my previous post again or do you not understand pre and post?
  7. Re: Whats wrong with my car?
    Sep 2008
    To be honest with you i dont understand what you mean by pre and post.
  8. Re: Whats wrong with my car?
    134 Post(s)
    2007 Post(s)
    Pre is before and post is after.
  9. Re: Whats wrong with my car?
    Magdeburg, Germany
    Before you start doing anything real it would be neat to see a full diagnostic protocol which has control module part number as well as software version...
    Sebastian @ www.Ross-Tech.com
  1. Please Help Whats Wrong with My 1.9td 05 Transporter?
    By Andi Millson in forum The Commercial Range
    Last Post: 24-06-2008, 08:22 PM
  2. Please Help Whats wrong?
    By Dobbo_84 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 21-06-2008, 01:38 PM
  3. My New Car - Whats Wrong???
    By DORA in forum Beetle 2000-
    Last Post: 05-05-2008, 07:35 PM
  4. Emissions lights is on..Whats wrong!!!
    By jay17 in forum Golf MK4 - 1999 - 2004
    Last Post: 18-04-2008, 09:22 PM
  5. Whats wrong with my 80????
    By AndyAudi80 in forum 80 - 90
    Last Post: 04-10-2007, 06:40 PM
