Thread: courtesy light and door light
  1. courtesy light and door light
    does anyone now where the switch is that controls these lights as mine work when they feel like and i cant see any switches anywhere
    Quote Originally Posted by dazzy4 View Post
    could you give a better description of the fault please? does it happen in specific weather conditions, certain doors, etc?
    hi yes the problem is on the drivers door i know the lights work and the bulbs are ok as it only happens now and again if i open and close the door repeatedly it might work once in five attemts is it a faulty switch os a loose connection do you know where the switch is
    no 'switch' that i know of, it operates on the same kind of system you would find on your fridge for that light... there will be a plastic 'knob' which pushes in when your door closes, this then turns the light off.
    id check that isnt stuck in, might be stuck in with c**p, if thats not the problem, your bulb might be loose in the holder, you can prise the actual thing out of the door using a flat edged screwdriver i think, if not you may have to take the door card off and push it out to check, its not that hard really. other than that, there could well be a fault in the wiring, but i doubt it, it sounds as though your bulbs just a bit loose in the holder....
    found the switch it is located along side or within the door lock seems to be sticking lashed it wd 40 to try and free it took the door card off and then realized it was to much hassle to take a steel door card off wich lies behind it why is everything that should be easy time consuming put the switch back on the pillar where should be
    what 'switch' do you mean here? any chance you could take a picture and post to stop any confusion?
  7. Thumbs up
    i am refuring to the switch that operates the courtisy lights and the light in the door on my mk4 golf on older cars u would have a switch on the door pillar by the hinges it would work by the door opening and closing pushing the switch on and off
    well thesre isnt one on my golf there probably isnt one on yours either have you looked
    i found out that the lights are operated by a switch that is built in to the door lock when you open the door the door catch is released and it makes the switch when you close the door then it turns them off have a look see what u got
  1. Door Light Rear not working
    By Anzee in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-03-2008, 06:05 PM
  2. Brake Light / Tail Light Changing Avant
    By Gazz in forum Audi A4 - Archive Topics
    Last Post: 20-11-2007, 10:23 AM
  3. courtesy light
    By SpaceMonkey in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-06-2007, 10:08 PM
  4. Exhaust/Engine Emission Warning Light Constant Orange & EPC Light intermittent!
    By karl578 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-06-2007, 10:59 PM
  5. Only the high level brake light and flahing coil light
    By 49forever in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-05-2007, 04:41 PM
