Thread: Dump Valve On Mark 4 Golf
Results 1 to 8 of 8
  1. Dump Valve On Mark 4 Golf
    Feb 2007
    just put a dump valve on my golf 1.8T and a few days later my engine management light has come on can anyone shed some light why this is?
    Northern Ireland
    its something to do with the wastegate... vw engines and the 1.8t inparticular dont like dump valves..i could tell you why ..but ud be better to ask a mechanic..i dont want to give u the wrong info mate. but if ya want i could soon find out
    cheers chris
    Feb 2007
    would i be causing any damage driving my car with the management light on? one of my friends is a vag mechanic so he is on the case to find out more info for me, do you know if there is a easy way around this problem? or is the best way to just get a re-circ valve? which will obviously make no noise? thanks for your help
    if it ent broke, dont fix it, cliche i know but always true and always works! i would think the best thign to do, get the car back to using the parts it was using before you put that dump valve on it. if your mate is a VAG mechanic, heel be able to do this pretty easily, should be bolt on bolt off business.... same would apply to your other post abut this
    london/ UK
    Quote Originally Posted by vwgolfturbo View Post
    Forge recirculating valves are designed to replace the standard OEM plastic Bosch jobbie ! See their website for more details...Hope this helps...
    Feb 2007
    in hiensight yeh i would have left it as standard,but too late for that now,so by the looks of things i am going to have to replace everything i took off and cut into and blank off to fit the bailey valve and replace the original dump valve with a forge one. oh well. does anyone know if i am going to cause my engine/turbo any harm by running my car for the next coupple of days until i can get this fixed?
    i wouldnt have thought so.... would think the EMS light's on because the turbo isnt working in the recognised way without that recirc valve. might need a techies opinion on that one though!
    Feb 2007
    Thanks For The Help Mate,think I'll Go And Order A Re-circ Valve From Forge N Get It Fitted And All The Necessary Pipes Replaced This Week,oh Well At Least I Had The Ptisssssshhhhh Sound Without Any Problems For A Few Days! Sounds Very Good! Shame The Ecu Is So Sensitive.
    VW GOLF TURBO
  1. Golf GTI 1.8 T Dump Valve
    By vespapete in forum Archive posts
    Last Post: 05-02-2008, 02:14 PM
  2. 1.8t Dump valve
    By Nav_1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-06-2007, 02:15 PM
  3. S3 Dump Valve?
    By HappyS3Owner in forum Audi A3 - Archive Topics
    Last Post: 25-04-2007, 05:36 PM
  4. replacing atmospheric dump valve with re-circ dump valve
    By vwgolfturbo in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-02-2007, 10:27 PM
  5. dump valve
    By shaunw84 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-01-2007, 12:21 AM
