Thread: Front Hub Bolt Torque Setting
  1. Front Hub Bolt Torque Setting
    Taunton
    What is the Torque setting for the front hub bolt.. 99 Passat 110 tdi. and what is this angular torque lark all about!!!
  2. Re: Front Hub Bolt Torque Setting
    Verwood, Dorset
    I'll have a look in the haynes manual tonight.. I did it recently but can't remember what it was off the top of my head.
    Tom.
  3. Re: Front Hub Bolt Torque Setting
    Verwood, Dorset
    Depending on what size hub bolt you have there are differing torque settings.
    16mm = 140 lb ft Then tighten a further 180 degrees of rotation.
    14mm = 85 lb ft Then tighten a further 180 degrees of rotation.
    Thats what it says in the Haynes manual.
    Hope that helps mate.
  4. Re: Front Hub Bolt Torque Setting
    May 2006
    You can get an adapter that fits onto the square drive of the torque wrench which shows the angle that you have moved the torque wrench through. Another way would be to drop a string and plumb bob from the top of the wheel arch. Line the torgue wrench up with the string and then turn it through the 180 degrees to line back up with the string. A fair bit of force will be required to move the torque wrench through the required angle.
    Don't forget to use a new bolt,
  5. Smile Re: Front Hub Bolt Torque Setting
    Taunton
    Thanks all for the replies...
  1. Fitting roof bars to passat saloon, in particular using the torque setting tool
    By PNS2007 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-07-2013, 11:40 AM
  2. Question Big End Bolt Torque
    By marshp in forum Golf MK3 - 1993 - 1999
    Last Post: 17-08-2008, 03:22 PM
  3. MK5 GT Road wheel bolt Torque setting
    By steve baker in forum Golf MK5 - 2004 - 2009
    Last Post: 03-09-2007, 12:47 PM
  4. head torque setting 1.9tdi
    By gavst4 in forum The Commercial Range
    Last Post: 31-08-2007, 10:49 PM
  5. Golf Gt tdi (140) Sump plug torque setting.
    By richard_vw in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-08-2007, 10:54 AM
