Thread: Noise from front O/S wheel
Results 1 to 10 of 14
  1. Noise from front O/S wheel
    May 2008
    Hi all
    Your help would be appreciated on this. I have a noise/vibration coming from the front o/s wheel which I thought was the wheel bearing. Having changed the bearing this weekend the noise is still there!
    When making a right turn or going over a bump that takes the weight off the wheels the noise dissapears but is constant in a straight line.
    Car is a 1989 Golf 1.6TD.
  2. Re: Noise from front O/S wheel
    Benignus Guest
    Is it a clanking noise - intermittent and usually heard on speed bumps or rough bits of road at slow speeds?
    If so it may be your upper strut bearing. Available from VW or GSF.
  3. Re: Noise from front O/S wheel
    Check the balancer weight hasn't come loose on the driveshaft and has slid down the shaft towards the wheel. This allows it to contact things that it shouldn't. When cornering the postion of the shaft alters in relation to the body and may alleviate the problem temporarily.
    It can make an awful racket but is unlikely to do any real damage in the short term. A quick emergency fix can be made with a bit of sellotape to lash it to the diveshaft!
    If it's not this, then it might be worth having a quick check on any play in the cv joints??
    Happy troubleshooting,
    R
  4. Re: Noise from front O/S wheel
    May 2008
    Thanks for the replies. The noise is more of a droning that increases with speed. Thats what made me think it was the wheel bearing. There's no clanking that I can hear.
    Someone has suggested that it might be the CV joint?
    Thanks again
  5. Re: Noise from front O/S wheel
    Have you had a chance to look underneath yet?
    Probably best to jack up that corner and give everything a good wiggle - a loose wheel bearing or worn cv joint should be readily apparent once there is no load on the part.
    Best to eliminate possibilities to diagnose the fault.
    R
  6. Re: Noise from front O/S wheel
    May 2007
    Edinburgh, Scotland
    Does sound like a wheel bearing to me. Sure it's coming from that corner? Sounds can be deceptive inside the car.
    1991 Golf 2 Driver.
    1.6 EZ
    "THE BEAST" also known as "THE SHED"
  7. Re: Noise from front O/S wheel
    May 2008
    Dartmoor
    You wont be the first to have changed the wrong side wheel bearing. My 250,000 mile polo droned hellish on clockwise turns. Changed nearside wheel bearing, droned hellish on clockwise turns. Canged offside (ie the one it shouldnt be!) and quiet as a lamb. Does anybody know if it is a weird quirk of those VW bearings?
  8. Smile Re: Noise from front O/S wheel
    lucan138 Guest
    It definately sounds like cv joints, just had mine done on Audi A4 1.8 Auto
    Cost £98 each joint
    No more noise or problem
    Good Luck
  9. Re: Noise from front O/S wheel
    May 2008
    Quote Originally Posted by lucan138 View Post
    Cost £98 each joint
    Good Luck
    Well, its not the CV joint either! Just changed it and noise still there. Fortunately it was only £22 from Virgin Autoparts and was a piece of cake to change so not too big a deal.
    Quote Originally Posted by Smutts
    Hmmm - maybe....... Guess thats next weekends job then!
    Thanks again for the replies
  10. Re: Noise from front O/S wheel
    May 2008
    Dartmoor
    Good luck, I will be up to the same IF it stops pouring down. The last time I did this...... Haynes- "simply tap out the bearing with a suitable drift" Real Life-"beat it gently with hammer, beat it some more with lump hammer, beat h*ll out of it with sledge hammer, find that I've broken all my paving slabs, give up, walk 3miles to engineering shop with offending item. It simply pressed out with 19 tons showing on the guage. Life must be nice on planet Haynes . I've saved up for the pukka Sealy bearing kit, looks as though it will do nicely.
    Be carefull with the hub flange though, as I managed to bend it slightly last time prying off the bearing inner. Brake vibration results. Have fun, and don't loose your temper too much.
  1. Humming/Droning Front Wheel Noise!!
    By wrightypm in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-12-2013, 09:15 AM
  2. Audi A4 Front N/s Wheel Suspension Squeaky Noise
    By cbi004 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-07-2009, 12:29 PM
  3. Audi A4 Avant (2002) front wheel noise
    By linuxmad in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-09-2008, 10:53 PM
  4. Squeaky noise from drivers side front wheel and harsh gear change (triptonic)
    By jasear in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2008, 02:20 AM
  5. what is the box in front of wheel on the NS
    By mbu10 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-04-2008, 06:07 PM
