Thread: help climate control panel not working
  1. help climate control panel not working
    Aug 2008
    hi i wonder if any of you guys out there can help. today i decided to fit a new head unit to my mk4 i had to pop out the climate control (but didnt disconect it )to pull the wires through from behind the radio as i was fiting radio back in pop i blew a fuse checked and replaced it radio works but no climate control its as if the fuse has gone pop but i have checked all fuses and all ok. also oil senser workshop comes up on screen with a beep when i start up any help will be much apriciated
    thanks Dan
  2. Re: help climate control panel not working
    Sep 2008
    Was the ignition off when you fused it?
    If so you need to checkout the system feed, the one that feeds radio memory, I know you said you checked ALL the fuses, but if you short'd it and now its not working, then it is a fuse.
  1. Replies: 2
    Last Post: 08-08-2008, 10:53 PM
  2. Please Help Climate Control Panel Removal Procedure
    By pologt in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-07-2008, 04:01 PM
  3. bora tdi climate control panel dead?
    By swk71 in forum Bora - 1998 - 2005
    Last Post: 22-07-2008, 02:23 PM
  4. climate control not working
    By salty in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 18-04-2007, 09:11 PM
  5. Is my climate control working right
    By spainy in forum Audi A4 - Archive Topics
    Last Post: 11-03-2007, 08:19 PM
