Thread: ABS Sensor problem.....PLEASE HELP
Results 1 to 8 of 8
  1. Exclamation ABS Sensor problem.....PLEASE HELP
    May 2008
    Rainham
    My 1999 Golf GTI 1.8t is indicating that there is an ABS fault + the ABS light is on,along with the brake pad light on the dash.It was put on a computer and i was told that it was the passenger side front ABS sensor! I got 1 and had my friend (who's a mechanic) fitted it.When he did so the brake pad light came off but no ABS light! I dont understand as it has new break pads on it....
    Is there more than 1 sensor on the passenger side front wheel or where do i go from there??
    Im needing to get it done asap as its goin up for sale!
    If anyone can help it will be most appreciated.
  2. Re: ABS Sensor problem.....PLEASE HELP
    Sep 2008
    Birmingham
    You may have to plug a diagnostic machine in to clear the fault code, should be ok then.
  3. Re: ABS Sensor problem.....PLEASE HELP
    May 2008
    Rainham
    Do you normally have to put it on the computer? I just dont get why the brake pad light is off now but the ABS light stayed on once the sensor was fitted!
  4. Wink Re: ABS Sensor problem.....PLEASE HELP
    Sep 2008
    Birmingham
    Quote Originally Posted by Richie84 View Post
    Some fault codes store permanently on the ECU until rectified and then cleared. It's a very good way of making revenue for manufacturers.
  5. Re: ABS Sensor problem.....PLEASE HELP
    May 2008
    Rainham
    Ok thanks,il give it a try
  6. Re: ABS Sensor problem.....PLEASE HELP
    london/ UK
    Unless there is still a fault with the ABS system, the light should go off untill the probllem reoccurs. ABS system has a self checking system wich works for 30sec. or so, every time the engine is started. So i would do a diagnostic check and see what other fault codes are logged...
  7. Re: ABS Sensor problem.....PLEASE HELP
    Dec 2007
    Suffolk
    Have you taken it for a drive? Some times that willput the light out when the system can see everything is working correctly.
  8. Re: ABS Sensor problem.....PLEASE HELP
    131 Post(s)
    1976 Post(s)
    Sounds like an open circuit on the wiring harness on the left front, we have had to change quite a few and it is fiddly to do.
  1. Question map sensor problem
    By arnie909 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-07-2008, 07:40 PM
  2. ABS Sensor Problem
    By wodger in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-07-2008, 02:27 PM
  3. A4 .18T speed sensor problem. HELP!
    By a4_jim in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-06-2008, 11:09 PM
  4. oil sensor and Climatronic problem !!
    By wrightypm in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2007, 12:13 AM
  5. Uh oh, another MAF sensor problem??
    By Slowgolf! in forum Golf MK4 - 1999 - 2004
    Last Post: 12-09-2007, 09:21 PM
