Thread: mk4 2l gti problem
  1. Exclamation mk4 2l gti problem
    Hull
    Hi..
    I am having a problem with my mk4 golf 2l gti..
    every now and then the engine rev's are sticking/ goin higher when i take my foot of the accelarator or push the clutch pedal down.
    The only way to stop this is to pull over and turn the engine of and re-start (which takes forever and when it does re start there is a strong smell of petrol)
    Any idea's what this could be as its happeneing more and more often??
  2. Re: mk4 2l gti problem
    Jan 2008
    Angus, Scotland
    If it had carbs I would say that the flap is sticking open, but as it's a GTI I'd hazard a guess at the throttle body sticking!
    Don't know a great deal about injection systems so could be way off the mark but would have a look and see if the TB is gummed up!
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  3. Re: mk4 2l gti problem
    2009 Post(s)
    What is the year and engine code?
  4. Re: mk4 2l gti problem
    Hull
    its an X reg 2000 modal.
    Were do I find the engine code?
    cheers!!
  5. Re: mk4 2l gti problem
    2009 Post(s)
    It’s on the data sticker inside the front cover of the service book, on the data sticker on the boot floor, on your V5 and on a sticker on the cam belt cover.
  1. Stuck door problem, central locking problem & no alarm
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2008, 05:57 PM
  2. Air Conditioning problem or display problem?
    By Doug999 in forum Archive posts
    Last Post: 02-01-2008, 11:59 PM
