Thread: golf fuel economy
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 57
  1. Re: golf fuel economy
    Sep 2008
    East Midlands, Somewhere
    Actually, coasting down to the lights in neutral uses more fuel than backing off in a high gear. Watch the instantaneous consumption and it will read --- for no fuel use. This is due to a function known as overrun cut off that cuts the fuel completely during the overrun as the inertia of the car keeps the engine turning. Try this on an open stretch and let the car come right down to almost a stop and it will suddenly kick back in and trickle along.
    Might sound like a silly question, but when you say backing off in high gear, do you mean leaving the car in gear but taking your foot off the peddle?
    And does anyone here have any idea why my car sounds louder than most? Ive taken care of it since ive had it and so have the previous drivers (I assume as it has full service)..
  2. Re: golf fuel economy
    Sep 2008
    Quote Originally Posted by HOS View Post
    In reply to Golf TDI you mention that your friend thought your car sounded loud, as this is my first golf but second diesel I have to say that this is my impression of my TDI at low revs ie pulling away, in fact after my Mazda 6 diesel it is very loud on low revs.
    Is this the norm for the mk5 1.9 TDI or is it a Problem.
    Hey HOS, well its common knowledge that Diesel cars are naturally louder as me and you are both aware. However, my friend is quite knowledgeable about cars and he said that my car sounds muchlouder than it should.. I dont have any idea, he said it could be anything and it sounds like its coming from the bottom of the car (he suggested exhaust ).. Im really worried now, I hate having car problems especially when I treat it right
  3. Re: golf fuel economy
    Mar 2008
    Old Wessex
    From my personal experience I would say there is a problem with your car! As for what the problem actually is, I'm afraid I can't help there.
    My car is a 2.0 GT TDI Golf on a 55 plate; I regularly return figures in excess of 65mpg on my drive to and from work, and It never drops below 55mpg, even on motorways or zipping around town. I usually average around 600 miles to a full tank. I believe the 1.9 TDI engine is more frugal than the 2.0; so going by comparison to my car I'd say there is something not quite right.
    As for not exceeding 1800 rpm, this isn't a good idea. The engine needs to be revved every once in a while or the turbo will get blocked up.
  4. Re: golf fuel economy
    Sep 2008
    Thankyou gentlemen for your replies, I'll be refueling tonight and will re-calculate mpg (after using fuel additive) although I dont think it has improved, I'll let you know the result. Cheers Hos.
  5. Re: golf fuel economy
    134 Post(s)
    2022 Post(s)
    Quote Originally Posted by Golf_TDI View Post
    Yes, just driving as you would be taught to do if taking your advanced driving test. For example driving along a main road at 40 mph and the lights ahead change to red and instead of dipping the clutch and/or knocking it into neutral or even changing down through the gears, you approach the lights in the gear you were it with the clutch engaged and dip the clutch as the car just begins to drag. Not only does this reduce fuel consumption over approaching the lights at idle but obviously it also reduces emissions to nearly zero.
  6. Re: golf fuel economy
    Sep 2008
    Quote Originally Posted by the surfer View Post
    Arghh! surfer now im worried ..
    Does anyone know what the problem is?!
    What I do around once a week is rip the car in high revs, because Ive been told plenty of times that the Turbo gets blocked up.. Whats the ideal way to drive the Golf then? im so confused, I thought 1800 revs and smooth gear changes was the way forward.. SOMEONE HELP
  7. Re: golf fuel economy
    #17
    Sep 2008
    Just refueled and calculated combined mpg (taking it very steady no hard right foot) and reached the dizzy heights of 39 mpg.
    Off too the garage?
  8. Re: golf fuel economy
    #18
    Jul 2008
    High Peak, Derbyshire.
    It's an interesting one this. My Mk5 has had a few probs since I bought it as an approved used car in July.
    But fuel consumption isn't one of them. I'm getting just a tad below 50 and that's with quite a few short journeys (I only do 5,000 or so miles per year).
    I had an air flow meter fail on a Bora TDI about 4 years ago but this was also accompanied by poor performance.
  9. Re: golf fuel economy
    #19
    134 Post(s)
    2022 Post(s)
    I think you should have a fault code read done and see what the garage says about the cars performance as AMM’s (MAF’s) are a big problem. If you do have one fitted, make sure it is a genuine VAG part bought from the VAG TPS or VW dealer, no where else no matter what the garage tries to say-insist.
  10. Re: golf fuel economy
    #20
    Sep 2008
    Thanks for the suggestion CRASHER, but excuse my ignorance, what is an AMM/MAF?
  1. Golf mk4 1.6 s very bad fuel economy
    By baz2963 in forum Golf MK4 - 1999 - 2004
    Last Post: 17-12-2007, 01:39 AM
  2. Fuel economy on a '99 1.8 SE
    By redman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-07-2007, 08:58 PM
  3. Poor fuel economy on my Golf?
    By AndyF in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-07-2007, 08:44 PM
  4. Poor fuel economy golf tdi
    By clem750 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-06-2007, 03:14 PM
  5. Fuel Economy Golf MK3 1.8 se
    By markgrocock in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-06-2006, 09:40 PM
