Thread: Vibration Noise
Results 1 to 8 of 8
  1. Vibration Noise
    Dec 2006
    I have a 2002 1.9 TDI Passat with 80k on the clock, when im pulling away in a low gear, especially on a hill I am getting a vibration noise.
    Doe sanyoe know what this may be, on reading up online it sounds like it may be my dual mass flywheel and clutch?
    Others have said may be my auxillary belt? Its a wierd noise, sounds like the call will stall, and you lower clutch and its OK. When the car is idling you can also hear it.
    The MPG on car is fine so not effecting fuel consumption.
    Any views be great
  2. Re: Vibration Noise
    135 Post(s)
    2027 Post(s)
    That could be DMF failure but it is difficult to say. Removing the starter can help diagnose this, if it is covered in goo then it will be the DMF.
  3. Re: Vibration Noise
    Dec 2006
    Sorry what is the DMF?
    thanks
  4. Re: Vibration Noise
    Taunton
    Dual Mass Flywheel.. Expensive!!!Hope it is'nt. Sorry mate!!
  5. Re: Vibration Noise
    Dec 2006
    Ok thanks mate, this is what I heard before it may be, got a uote for £600 for clutch and flywheel from mr Clutch, will have a look at the below next weekend and see if its covered in goo, if it is will have to get it sorted :O(
  6. Re: Vibration Noise
    Taunton
    I had my clutch done by Mr Clutch in Bristol.. I was lucky as the DMF was OK. I would recommend them as I was satisfied with the service they gave me. They give a warranty and it took about 4 hrs.
  7. Re: Vibration Noise
    Dec 2006
    Thanks again, much appreciated, out of interest what was the cost for just clutch, just so work out what the difference is incase its just the clutch and not DMF, thanks
  8. Smile Re: Vibration Noise
    Taunton
    £315 inc Vat.. This was last Feb. as I said this was Bristol so if you are near there give them a ring>
    all the best.. H...
  1. Noise And Vibration When Turing Right
    By reesfamily26 in forum Touran - Sharan - Caravelle
    Last Post: 03-08-2008, 05:19 PM
  2. Buzzing vibration noise at 2400rpm
    By cara_essex in forum Golf MK3 - 1993 - 1999
    Last Post: 17-04-2008, 04:59 PM
  3. vibration noise ?? is it fixable?????
    By muddybuggy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-03-2008, 09:56 PM
  4. Knocking noise and vibration
    By ash71 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-01-2008, 04:52 PM
  5. vw passat vibration noise and feel
    By gosp2004 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-12-2007, 01:48 PM
