Thread: Noisy air conditioning
Results 1 to 9 of 9
  1. Noisy air conditioning
    Oct 2006
    New to the forum and wondered if anyone could help.
    I have a Passat TDi 1.9 2003.
    In the past few weeks the air conditioning is making a quite audible (and annoying!) whirring sound. However, when I turn the air co to ECON setting, the whirring disappears.
    This problem seems to have coincided with the installation of a new cam belt - but this may just be a coincidence.
    If anyone can help advise what the probable cause is I would be very grateful.
  2. Re: Noisy air conditioning
    Sep 2008
    Birmingham
    I'm interested to know the outcome of this as my mate's B5 developed the same problem in the last couple of weeks, his is a deep drone that at times you can feel resonating through the car.
  3. Re: Noisy air conditioning
    Dec 2007
    Suffolk
    It sounds like a problem with the compressor, Has the A/C been regassed lately? They make a drone when they are overcharged (too much gas ,ive done it on a pajero)
  4. Re: Noisy air conditioning
    Sep 2008
    Birmingham
    It hasn't been regassed (he's too tight to turn it on, let alone regassing it ), permanent econ. But the car was serviced a couple of weeks ago.
  5. Re: Noisy air conditioning
    To do the TB the Compressor drive belt is removed, I suspect it have been refitted and over tensioned. Take it back and get *** checked out. Yes in Econ mode the compressor does not run. Regards Peter
  6. Re: Noisy air conditioning
    Oct 2006
    Many thanks for the suggestions chaps.
    I think it sounds like the the issue is with the belt tension.
    Regards
    Stefan
  7. Re: Noisy air conditioning
    Taunton
    Check the AirCon belt idler.
  8. Re: Noisy air conditioning
    Stafford, Midlands
    Quote Originally Posted by euroslap View Post
    mine is on constantly, dont see the point in not using it, i dont notice any change in mpg, its never on econ, usually about 19c with 2 bars blowing through to front screen, if its cold, i have it on about 23c with 3 bars blowing lo through dash vents. still get a lot of mpg
    Subaru broken, sold, Silver Seat Leon Cupra 180 '02' no cupra badge?
  9. Re: Noisy air conditioning
    If the outside temp is less than the temp requested then it does not use the A/C compessor except when first driven after being parked in the sun. If it is cool outside it is better to leace the the A?C off by sellecting Econ. Regards Peter
  1. Air conditioning
    By tania joubert in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 11:15 AM
  2. Is it possible to add air conditioning?
    By flying fish in forum The Commercial Range
    Last Post: 16-08-2008, 05:59 PM
  3. Air Conditioning
    By Reggie in forum Scirocco - Corrado
    Last Post: 19-08-2007, 07:49 PM
  4. Air conditioning.
    By Brian Rouse in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-08-2007, 10:44 AM
