Thread: Secondary Air Valve....?
  1. Secondary Air Valve....?
    Oct 2007
    Cheshire
    Evening Lads,
    Its just re-occured to me that while my remap was being done the other day, the guys at Votex said that my secondary air valve threw in a fault code, but once reset, didnt come back again...didnt occur to me at the time to get the actual code...
    SO I guess what I could do with knowing is....
    1. Whats it do?
    2. How will I know when/if it packs up?
    3. Is this going to become an issue, something I need to start saving for or could it be a blip?
    Any thoughts gratefully received!!
    Cheers in advance!
    1999 Audi S3 now revo'd
  2. Re: Secondary Air Valve....?
    May 2007
    knee deep in clunge
    14 Post(s)
    PUMPS more air into the intake from cold start to reduce emissions and warm the engine quicker.No real issues with this system but the occasional pump packs in and the vale can stick
    vag diagnostics, retrofits and general repairs
  3. Re: Secondary Air Valve....?
    Oct 2007
    Cheshire
    Thanks for that A8, at least I know what it is now.
    SO am I looking at multi-pounds to sort out if/when it fails? Where would I find it? Pretty sure he said it was the valve that logged the fault?
    Cheers again!
  4. Re: Secondary Air Valve....?
    Birmingham
    It's a small valve that sits under the plastic cover on your intake, not sure on the cost though. Can't see it being a ludicrous ammount.
  5. Re: Secondary Air Valve....?
    my mate had this problem with the secondary air pump throwing the engine management light on, earlier models don't do this as it doesn't communicate with the ecu, the pump itself which is located at the front of the engine gets a small air leak and thats what causes the light to come on, you can overcome this and save a hell of a lot of money by removing the air pump, drilling out the rivets that keep the pump together and replacing them with i think m4 bolts and nuts, this will more than likely cure your problem as it tightens the seals up and stops the air leak.
  6. Re: Secondary Air Valve....?
    the light will reset itself after a good few miles, or alternativly you can have it erased and let someone have your pants down.
  7. Re: Secondary Air Valve....?
    May 2007
    knee deep in clunge
    14 Post(s)
    Quote Originally Posted by SEMKY View Post
    Cheers again!
    Most common fault is the combi valve sticks and stores a sporadic fault,just clear the code and carry on.If the light comes back on post the fault code and i will advise the best route to take.If the pump is leaking or a pipe has come adrift (which they do) it will sound like you have a hair dryer under the bonnet from cold start
  8. Re: Secondary Air Valve....?
    Oct 2007
    Cheshire
    Thanks very much for that Paul, will bear it in mind!!!
    And thank you very much A8, thats very good of you. The chap at votex mentioned something about the hairdryer....I have never heard anything like that, but will keep an ear out....
    I never had an engine management light come on, but if I do, or if I hear anything, I'll get a fault code next time!!
    Thanks again guys,
  1. 2.7T Secondary air pump
    By audipersempre in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 19-06-2008, 09:17 AM
  2. Fault Code PO411 - Secondary Air Solenoid Valve (SASV Y75)
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-06-2008, 07:32 PM
  3. Secondary air pump
    By drummie in forum Alhambra
    Last Post: 27-01-2008, 07:21 PM
  4. secondary air pump
    By Russ in forum Archive posts
    Last Post: 30-11-2007, 10:00 AM
  5. Secondary Car Alarm
    By andysuth in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-12-2006, 12:43 AM
