Thread: A3 Quattro
  1. Talking A3 Quattro
    Wisbech in Cambridgeshire
    Hi this is my first post, anyway i am looking for a 8L Quattro but i am wondering if there is anything special i need to look out for our listen out for while on a test drive, any common faults like the gearbox diffs etc also should i give high mileage cars a wide birth.
    James
  2. Re: A3 Quattro
    Oct 2007
    Cheshire
    Quote Originally Posted by A3Quattro1985 View Post
    James
    The quattro system on these is pretty good, and I havent heard many problems rearing their ugly heads.
    The majority of the time, it works as a two (front) wheel drive, and the Haldex coupling is like a hydraulic clutch that is engaged as a difference in speed develops between the front and rear wheels.
    If its a high miler, make sure that the haldex oil and filter have been changed (I think its 20k for oil, and 40k for oil and filter but dont quote me on that) ....
    Make sure the cam belt, tensioner and water pump have been done around the 70K miles mark, and frequent oil and filter changes have been carried out.
    Other than that, if there are any scary noises from underneath get them checked.
    Like I say, I havent heard of any issues on here....one of the techs may have more to tell you?
    hope this helps
    JAMES
    1999 Audi S3 now revo'd
  3. Re: A3 Quattro
    hi, i have just bought an A3 quattro 8l myself, i did have a slight problem with lumpy gear change and a noise from the haldex unit on full lock but a change of gear oil in the gearbox, a treatment and also changed the haldex oil (which is the same oil grade as the gearbox) and the problems have gone and i f**kin love it!
    couldn't be happier with it
  4. Re: A3 Quattro
    May 2007
    knee deep in clunge
    14 Post(s)
    James
    Make sure the clutch is ok as there not cheap and try to scan the fault memory if they will let you for any hadex fault codes also if its a 1.8 turbo check its got a full service history and look for any invoices for engine repair and what oil has been used (mobile 1 or similar) also check the coolant is circulating and all the central locking works also make sure the air con is ok and the radio screen and dash are fault free.Apart from that there ok,o i forgot the gear box suffers from 2nd gear failure and the internal clutch slave cylinder leaks and the master cylinders fail.
    vag diagnostics, retrofits and general repairs
  1. A6 2.7T Quattro
    By irfanali_1 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-02-2008, 06:55 PM
  2. to quattro or not to quattro?
    By dansansome in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-01-2008, 10:26 AM
  3. Quattro or not to Quattro
    By tholor1968 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-01-2008, 08:53 PM
  4. 1.8T or 1.8T Quattro
    By nickpw27 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-12-2007, 01:17 AM
  5. A3 quattro or not????
    By spadey in forum Audi A3 - Archive Topics
    Last Post: 11-04-2007, 07:53 PM
