Thread: Passat Brake Fluid Change...
  1. Passat Brake Fluid Change...
    Dec 2006
    I've just had the front flexi brake hoses replaced on my passat tdi 110 for the MOT and the brake fluid was replaced too. The brakes aren't quite as sharp as they were, obviously you get used to your brakes fairly quickly, so I'm not so aware of it now. The reseviour has enough fluid in it. I'm assuming this is normal, but can someone explain why? Pads and disks have plenty of life in them too by the way.
    Cheers.
    Aug 2006
    Devon, UK
    If the new hoses are not as resistant to expansion when under pressure, they will sap away power from the brakes (due to maximum pressure not being applied to the brake pistons). Perhaps they will stiffen up with time?
    As for the fluid, I would guess it's fine as it's new and should have been bled properly etc...
    Passat Sport Estate 2001 1.9 TDI PD
    100k miles
  1. brake fluid
    By clint in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-06-2007, 05:33 PM
  2. Brake fluid - dot 4 or 5.1?
    By wid77 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-03-2007, 10:10 AM
  3. A6 1.8T Brake fluid warning light
    By Cambrai in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 11-03-2007, 12:39 PM
  4. Brake Fluid, when was yours changed?
    By skymaster in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-03-2007, 01:33 AM
  5. Do I need to change brake fluid?
    By curiousgeorge in forum Archive posts
    Last Post: 16-01-2007, 09:08 PM
