Thread: A6 DAB radio retrofit
  1. A6 DAB radio retrofit
    I just bought an A6 Quattro Allroad with MMI satnav etc forgot to order DAB radio. anyone know if its possible to retro fit DAB or where i can source a unit. i believe the DAB unit is Kenwood also what location it is fitted and any other bits i might need
    cheers
    Tom
  2. Re: A6 DAB radio retrofit
    Mar 2007
    Andover Hampshire
    Hello there,
    I have an O3 plate A6 Avant 1.8T with the CD Navigation system.
    I bought and had fitted an Acoustic Solutions ICS-100 DAB unit and it works very well with a seperate windscreen screen mounted ariel.
    http://www.buyincardigital.com/acata...n_ics_100.html
    Te only criticism I'd have is that each time you re-scan for new stations you lose your presets but it only takes a couple of minutes to sort those out.
    And you'll not notice that the DAB signal is being broadcast over an FM frequency as the signal is as good as it can be.
    Hope this is of use even if it is a last resort for you...
    Audi Fan since 2003 and proud owner of a 2003 (03) Audi A6 Avant 1.8T Dual Fuel LPG, onboard Sat Nav and DAB Digital Radio
  3. Re: A6 DAB radio retrofit
    May 2007
    Poole
    These are pretty good as well - and have an input for a mp3 player of your choice!
    http://www.amazon.co.uk/Pure-Highway...=1LS5SWHTMT6C3
    Not as ideal as a built in solution though - but probably significantly cheaper!
    Julian Whitehead
    2001 A6 Avant 2.7T Q
    Swing Unlimited | www.subb.co.uk | www.myspace.com/swingunlimitedbigband
  4. Re: A6 DAB radio retrofit
    Jun 2008
    I've got an 08 A6 Le mans and enquired at the dealer I bought it from about retro fitting the DAB unit. Quoted around about a £1000 as the dash has to come out MMI updated and other electrical work......needless to say after I picked myself up I didn't bother having it done!
  1. Dis Retrofit
    By rigsby29 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-07-2008, 11:58 AM
  2. Retrofit CHorus/Concert Radio
    By barking71 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-10-2007, 10:52 AM
  3. ESP retrofit
    By redman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-09-2007, 06:30 PM
  4. A6 DAB retrofit
    By RickB in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-04-2007, 12:18 PM
  5. B5 Sat Nav Retrofit
    By JonathanK in forum Passat - Archive Topics
    Last Post: 31-12-2006, 04:59 PM
