Hi Guys,
My audi seems to be having intermittent problems for the last couple of weeks i need to know if anyone has had the same problem, basically every couple of days i have to keep refilling the oil but there is no sign of oil leaks plus add more water as the temperature light comes on and so does the oil light after i add the two things it's fine for a couple of days then back to the same thing......and ideas as to what might be causing this problem i have changed the breather pipe on it already.
