Thread: Failed MOT
  1. Failed MOT
    Tring, Buckinghamshire
    my car had its MOT yesterday and as you guessed, it failed. Nothing too serious just the odd ware and tear problems.
    I am hoping someone can help me here as I am none too good with electrics. One of the reasons it failed was the ABS warning light did not illuminate, I dont know where to start looking.
    Another problem is the front fog/driving lamps come on when the rear fog lamp are turned on. I didnt see the problem with this but hey it was a reason to fail.
    If any one can help out with advice or solutions I would be very greatful.
    Regards
    Simon
  2. Re: Failed MOT
    Gwent
    Does the ABS system work as it should? If so, it may jus be a blown bulb in the instrument cluster? If not, the ABS relay may be at fault?
    My foglights are the same as yours, they were on my other coupe too. I thought this was a standard feature?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: Failed MOT
    135 Post(s)
    2037 Post(s)
    What year and engine is the car? How long have you owned it?
  4. Re: Failed MOT
    The car in a 1993 2.0l 16v and i've owned it for about 6months
    Ill check the bulb and relays today and see if that helps
  5. Re: Failed MOT
    135 Post(s)
    2037 Post(s)
    No doubt the previous owner disabled the warning light to enable him to sell you the car, it is very common sharp practice. I would expect you to find the warning light disconnected and then you will need a fault code read but these cars require the earlier so called “2x2” to 16 pin adapter to allow the fault codes to be read.
  1. Failed Turbo
    By shooey88 in forum Golf MK4 - 1999 - 2004
    Last Post: 07-08-2009, 11:14 AM
  2. mot failed
    By lolly in forum Golf MK3 - 1993 - 1999
    Last Post: 04-11-2008, 02:56 PM
  3. Turbo Failed?
    By duffer in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 27-07-2008, 07:39 PM
  4. just failed my nct (DOE)
    By ossie in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 02-07-2008, 10:14 PM
  5. Failed MOT
    By cookie7354 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-04-2008, 12:38 PM
