Hi has anybody had a similar issue 2005 2.o TDi A4
If car is left for 2 hours or more and then started it starts but miss fires just for a couple of seconds and then is fine,
as the key is turned on you can hear a gurgle from the fuel tank.
if you prime the system by turning the key on and off several times until the gurgling stops it fires up fine.
There is i think an air leak in the system but there are no external fuel leaks visable.
I have changed the fuel filter and o rings but no difference.
if the car is started after it has stood a short while it is fine.
anybody had anything the same????
