Thread: VAG-COM/OBD Port locations
Results 11 to 20 of 25
  1. Re: VAG-COM/OBD Port locations
    May 2007
    does anyone know where the location is for a 1999 Mk 4 golf Gti is?
    ive looked on the location page but cant find it in any of the locations mentioned?
    thanks
  2. Re: VAG-COM/OBD Port locations
    Hello.
    2005 VW Touran please.
  3. Re: VAG-COM/OBD Port locations
    Oct 2005
    Quote Originally Posted by mez View Post
    thanks
    Under the heater controls there's a piece of fascia you need to remove
    Quote Originally Posted by andy8442 View Post
    Hello.
    From memory, pull open the coin tray beneath the headlamp switch and it should be behind that.
  4. Re: VAG-COM/OBD Port locations
    2daysway Guest
    I have an Audi A6 2002 2.5tdi se and would also like to know where the connection is and what it is, I am new to diagnostic tools, I do my own spanner work but this is becoming very restictive. can any one advice on the best lead and software to cover all the diagnostics for my car?
  5. Re: VAG-COM/OBD Port locations
    Oct 2005
    Quote Originally Posted by 2daysway View Post
    From the link in the first post;
    http://www.ross-tech.com/vag-com/car...ons/100a6.html
    The other part of your question will get more coverage in the VCDS forum - ask there
  6. Re: VAG-COM/OBD Port locations
    Nov 2008
    Anyone know where the port is on a 2000 fabia ?
  7. Re: VAG-COM/OBD Port locations
    #17
    Canada
    I would think its up under the dash to the right of the steering column.
  8. Re: VAG-COM/OBD Port locations
    #18
    Nov 2006
    derbyshire
    Hi, any idea where the port is on a LT van?
  9. Re: VAG-COM/OBD Port locations
    #19
    Ambler, PA, USA
    Can you read German? http://en.openobd.org/locations.htm#vw_lt_2d
    Google translated as follows: "The diagnostic connector is located in the footwell next to the pedals, it will need a special adapter. It may not have addressed all the control unit, as the LT a joint project with Mercedes-Benz."
  10. Re: VAG-COM/OBD Port locations
    #20
    Jul 2010
    Glos UK
    Quote Originally Posted by GTI_SI View Post
    R/H side of the dash there is a small pull down "glove box" effort. You need to give this a sharp pull downwards to expose the OBD port behind it.
    The OBD port for Skoda Roomsters is below the steering wheel behind the fuse board fascia.
  1. Vagcom/VCDS User Locations
    By Col in forum VCDS - Users Locations
    Last Post: 05-04-2025, 07:00 PM
  2. OBD Port
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-01-2010, 02:33 PM
  3. Whos the best garage? Post your locations and thoughts
    By Kev2904 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-02-2007, 02:24 PM
  4. Vag Com Port
    By Sharky_82 in forum Audi A4 - Archive Topics
    Last Post: 31-01-2007, 09:06 AM
  5. USB port
    By TheDufster in forum Passat - Archive Topics
    Last Post: 04-01-2007, 01:23 PM
