Thread: Windows and Sunroof.
  1. Windows and Sunroof.
    Sep 2007
    North Wales
    My 80 has been off the road awaiting work for it's MOT for about a month and when I came to move it today, I found that neither of the front electric windows or the electric sunroof would work. I've noticed before that sometimes they would take their time before working but after a minute they'd be ok, but now, nothing. Any suggestions please???
    Many thanks.
  2. Re: Windows and Sunroof.
    Jun 2007
    Gwent
    The relay controls both windows and sunroof, seems a likely culprit? It's tall and double width, mounted under the dash on driver's side (need to remove dash lower panel for access).
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: Windows and Sunroof.
    Sep 2007
    North Wales
    Many thanks for that, Scotty33. I did wonder if it was a relay.
    Guess what I'm doing this weekend???
  4. Re: Windows and Sunroof.
    Sep 2007
    North Wales
    How do I get the lower dash pannel out|?
  5. Question Re: Windows and Sunroof.
    Feb 2007
    Norwich
    Hi Coastie, did you fix your sunroof/windows problem?
    I have an 80 Avant B4 Tdi since new. It has had the same problem, maybe once or twice a year, usually when left for a week or two, I figured it might be an overload cutout when the seals were sticking and increased the start current. It was never bad enough or long lasting enough to investigate.
    This week the problem has changed character. It is here one mo, gone the next, then back again.
    I tried to find the right fuse circuit but cant seem to isolate power from a particular fuse (starting the troubleshooting process).
    But did you solve your problem, I see there are some other threads that mention similar issues, so I think this is a common type problem!
    Look forward to any help or relevant discoveries!
    Cheers,
    Tim
  6. Re: Windows and Sunroof.
    I don't have elec windows, but elec sunroof and the same thing. What is the relay and where is it located?
  1. Replies: 1
    Last Post: 14-10-2007, 12:06 PM
  2. mk3 sunroof
    By wilmot in forum Golf MK3 - 1993 - 1999
    Last Post: 17-09-2007, 04:29 PM
  3. sunroof
    By rampagey in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-07-2007, 11:21 AM
  4. Sunroof
    By magsnmartin in forum 80 - 90
    Last Post: 08-05-2007, 03:32 PM
  5. Sunroof
    By san in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-02-2007, 03:04 PM
