Thread: Newbie - 1994 Audi 80 TDI Estate problem
  1. Newbie - 1994 Audi 80 TDI Estate problem
    Aug 2008
    Hi, i'm a newbie and this is my audi
    very very clean, engine bay shots
    BUT it appears i have a leak somewhere, i suspect the sunroof. I have a puddle in my passenger footwell, the roof linig is wet where itr connects to the front pillar lining.
    ive cleaned out the 'guttering' that drains the sunroof and still no luck!!
    anyone had a similar issue? or has the solution? thanks
  2. Re: Newbie - 1994 Audi 80 TDI Estate problem
    Gwent
    If you have checked the drainage tubes are not blocked, I can only suggest there may be a leaking joint where the tube connects to the sunroof structure at the affected corner?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: Newbie - 1994 Audi 80 TDI Estate problem
    I just ran a heap of silicone (Bathroom tile sealer) under the apeture lip and anywhere I could see a possible leak coming from. Worked a treat. Messy, but works!
  1. TDI 80 estate 1994 - ABS problem
    By nickysteveo1 in forum 80 - 90
    Last Post: 26-07-2007, 12:51 PM
  2. passat estate 1.9 td 1994 correct tyre size
    By swonny2 in forum Passat - Archive Topics
    Last Post: 04-06-2007, 09:06 AM
  3. Newbie needs advice on tdi estate
    By cliveg in forum New Member Introductions
    Last Post: 30-04-2007, 01:27 AM
  4. AUDI 80SE 2.0L 1994 ECU problem
    By SteveE001 in forum 80 - 90
    Last Post: 08-01-2007, 11:02 AM
  5. Audi 80 tdi estate 1994 central locking
    By ColinM in forum 80 - 90
    Last Post: 09-11-2005, 12:09 PM
