Thread: starter motor help
  1. starter motor help
    Aug 2008
    I have an Audi a6 3.0 tdi just recently when I start the car I hear a loud click, some times it starts first time and other times it doesn't.
    I took the starter motor out and it was very dirty cleaned it all up, now the problem is when I connected it back to the car as soon as I put the negotiate cable back on the battery. the starter motor keeps on turning.
    have I connected the wiring it the wrong way.
    the picture shows the connection points on the motor. where does the white wire coming out of the motor go, to the left or right of the solenoid, the left bolt has 30 written next to it so I guess that is where the power cable goes?
    any help would be appreciated.
    picture attached.
  2. Re: starter motor help
    Chester-le-Street, United Kingdom
    the white wire will go to the left,and battery positve to the right.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: starter motor help
    Aug 2008
    hi
    i did try that and the startermotor does not run any more when i connect the battrey back on. the problem now is the solenoid clicks and the motor moves forward but does not spin?
  4. Re: starter motor help
    Dec 2007
    Suffolk
    Was your starter motor full of bits of metal? I think the DMF may of had it and took the starter with it.
  5. Re: starter motor help
    the internal contacts of the solenoid will not be "making" when it throws forward.
    they may be burnt out,or may just clean up if you are very lucky,but won't last long.
    stewy.
    4th cog,--two to go
  1. Please Help Starter Motor
    By Solari in forum Golf MK4 - 1999 - 2004
    Last Post: 30-07-2008, 12:03 AM
  2. Starter Motor
    By Ewster in forum Golf MK4 - 1999 - 2004
    Last Post: 09-03-2008, 11:06 PM
  3. Starter motor
    By schteeeeveeee in forum Audi A3 - Archive Topics
    Last Post: 24-01-2008, 04:32 PM
  4. Starter motor on its way out ... ?
    By ash in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-09-2007, 11:58 PM
  5. Starter motor for Mk3 Golf TDi
    By j_coupland in forum Golf MK3 - 1993 - 1999
    Last Post: 16-04-2005, 08:13 PM
