Thread: boost
  1. boost
    what can i do to stop my car losin boost higher up in the rev range .
    1.8 20v t
    I think its depending on your map - some maps are done differently - i think custom coding can map your ecu for power through different revs -
    Or
    The n75 J valve has been known to hold boost a little longer and boost but ive never tried it
    Some cars like it, some dont(i.e limp mode) -
    Have a look on the net for N75 J
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    Is it a boost leak?
    Jason - Rather mad Skoda Fabia driver.... Odd whiff of diesel coming from him.
    260bhp Skoda Fabia TDI Dyno Run
    http://www.youtube.com/watch?v=9BvjJjL7Z50
    315bhp Skoda Fabia TDI Dyno Run (2013)
    http://www.youtube.com/watch?v=TOE4nbT5NGY
    apologies, i was under the impression he meant in general - how to gain extra power at top end of revs -
    as per above - you having any issues with your car?
    noticed anything different when driving
    Aug 2006
    Devon, UK
    I've heard of owners in america adjusting the vane actuator so that it holds boost at higher revs, but I reckon this could cause limp mode, so you might need to get around that if you went down that road. It sounds like a simple idea that would then lead to other problems. Do plenty of research first!
    Passat Sport Estate 2001 1.9 TDI PD
    100k miles
    actuators should never be touched because they are electronically controlled - as you said, limp mode -
    which is what my car has got at moment - bloody annoying!
    thnx guys.
    it got the ko3 on it at the mo, iv just put a forge valve on it and theres so much boost from 2 till 4500 rev it lights the tyres up for fun, but after that it dies away. il try that n75j out is it the 1 off the tt225.
  1. A3 Boost
    By t0m541 in forum Archive posts
    Last Post: 27-03-2007, 09:01 PM
  2. A3 1.8T low boost?
    By head909 in forum Audi A3 - Archive Topics
    Last Post: 26-03-2007, 09:59 PM
  3. mk3 tdi no boost
    By robert1z in forum Golf MK3 - 1993 - 1999
    Last Post: 12-03-2007, 10:07 PM
  4. Boost controllers ??
    By jasonkay in forum Archive posts
    Last Post: 07-02-2007, 03:49 AM
  5. V6 TDI boost problem.
    By lowie V6 TDI Quattro in forum Archive posts
    Last Post: 07-09-2006, 10:18 AM
