Thread: Turbo Leak?
Results 1 to 8 of 8
  1. Question Turbo Leak?
    Sep 2008
    I've got a 2001 Passat 1.9 TDI 130.
    I'm experiencing what seems to be a leaky turbo system. I feel the turbo up to around 2.5-3k, then it drops to nothing and I basically have no power. If I pull off the throttle a bit I get a slight increase in power. To me, it feels like the turbo is ok until it is at full spool, after which the pressure is too high and is leaking somewhere.
    It looks like the previous owner had problems with the undertray and they drilled self tappers into a large rectangular pipe towards the front of the car. I'm sure I've felt and heard air leaking from this and that it's part of the turbo system.
    My local mechanic got it up onto a ramp, I showed him where I though the leak was coming from, and he said it's just structural and not meant to be air tight. I'm not a mechanic and couldn't really argue, but I think he's wrong.
    Can anyone give any insight into what this pipe is? I can take a pic if neccessary, but it's at the garage at the moment.
    Thanks,
    Lee
  2. Re: Turbo Leak?
    Quote Originally Posted by fullerlee View Post
    Thanks,
    Lee
    There is a tube across the bottom of the radiator, a pipe connects it to the intercooler, squirt some silicone sealant into the holes and try the turbo when it cures, if it works, tap the holes 1/8 gas and plug em!
  3. Re: Turbo Leak?
    Sep 2008
    Quote Originally Posted by caldirun View Post
    If I'm understanding you correctly, you say to fill the holes with sealant to see if that fixes the problem. I understand what you mean by tap the holes, but not the reference to 1/8 gas - can you explain in more detail please?
    Thanks,
    Lee
  4. Re: Turbo Leak?
    Thanks,
    Lee
    Sorry, BSP a tapered thread, used for gas-tight joints
  5. Re: Turbo Leak?
    Sep 2008
    Right I think I've got you, sorry for being thick, appreciate the help.
    My plan is this:
    1. Completely remove the undertray (so I can see where I'm working).
    2. Plug all the holes currently in the pipe with silicone sealant (stuff you'd use for water-tight seals in bathrooms etc?
    3. Wait for sealant to cure.
    4. Go for a spin to see if it's fixed.
    5. If fixed, use BS taper thread screws - Do I screw these into the sealant?
    Do you reckon that would be a permanent fix, or should I get it welded?
  6. Re: Turbo Leak?
    My plan is this:
    If its the tube that goes across the front below the radiator and has 60mm hoses attached at each end, its the turbo circuit, just tap it and plug it, use sealant on the threads as belt and braces. The under tray is just held with 5 turnbuckles and a 10mm AF nut, 2 mins to remove (assuming no nutter has drilled the turbo tube and put self tappers in it!!!)
  7. Re: Turbo Leak?
    Sep 2008
    I'm pretty sure that's the tube. If I put my finger over (one of) the holes and rev the engine, I can feel the pressure (and warmth!).
    One last question. It's likely that I'm still going to have to use the holes in the pipe to affix the undertray - the proper fixing arms have disappeared. Do you think I'll find a tapered bolt (plastic?) to be able to do this? If so - b&q?
    thanks,
    Lee
  8. Re: Turbo Leak?
    thanks,
    Lee
    Pop down the dealers and buy the brackets and fixings
  1. turbo oil leak. or could it be something else??
    By gemmell88 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-04-2008, 04:18 PM
  2. Turbo oil leak
    By Buzzlb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-04-2008, 12:06 PM
  3. 2.5 Tdi V6 Turbo Oil Leak
    By wadi110 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-03-2008, 08:46 PM
  4. Oil leak from top of turbo golf gt tdi 150
    By ian in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-04-2007, 11:04 AM
  5. TDI 130 turbo oil leak
    By Swanny130 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 11-04-2007, 10:59 AM
