Hi All
I am about to start installing a RNS510 in my 08 plate passat sport estate to replace the exisintg RCD500, I think I have all the steps detailed below but woud appreciate if anyone could review it to make sure I am not missing a step.
  1. Disconnect battery
  2. Remove trim from around exisiting stereo (do I need to remove the slide out drawers first, if yes is there any easy way to do this)
  3. disconnect air bag indicator
  4. remove 4 torx screw which secure RCD500
  5. Remove stereo and disconnect cables
  6. use twin connector : 4E0 035 608 K and antenna adaptator 000 098 707 to connect existing aerial leads to RNS 510.
  7. connect remaining block connectors into RNS510
  8. connect GPS antenna (still trying to decide where to locate this)
  9. connect air bag indicator and reconnect battery to try it out
  10. if all goes well refit trim etc
Am I missing anything important, any help much appreciated
Regards
Andrew
